Assuming i know the geometry and the rotation angle of a cart, how can i calculate the rotation angle of a swiveling wheel?
To get the rotation angle of the wheel, i tried by calculating the distance from the rotation axis, and to apply a friction coefficient:
var dx = cartCX - wheelCX,
    dy = cartCY - wheelCY,
    dist = Math.sqrt(cartCX * wheelCX + cartCY * wheelCY);
var wheelRotation = Math.atan2(-dy, -dx) * dist * friction;
But all this has not brought me any acceptable result.
Which is a simple way to get the wheels rotation angle about the Y axis when the cart is rotating?
I don't need exact physics simulation, just a smooth rotation angle which i can tween. I think there should be no need to use any physics engine, or i'm wrong?
deblocker
  • 113
When in doubt: Fake it.
Instead of calculating the wheels from where the cart is, calculate the wheel direction from where the wheel was.
Something like this:
//Constants, per wheel. I'm assuming Y is up/down
var wheelOffset = Vector3( -40, 0, -10 );
//Variables kept over multiple frames, per wheel
var wheelAngle = 0;
var lastWheelPosition = 0;
//Per frame:
//Calculate the world position of the wheel from the carts transformation matrix, there's other ways if you don't use a matrix but a matrix is probably the most common to use
var wheelPosition = cartTransformation * wheelOffset;
//Calculate how much the wheel moved, from *this* we can then calculate an angle
var wheelDist = wheelPosition - lastWheelPosition;
var newAngle = Math.atan2( wheelDist.x, wheelDist.z );
//This is the final angle we use for this wheel. There's various tweaks you can do to get behaviour you want. The 0.1/0.9 variables adjust how fast a rotation of the cart is send to the wheels
wheelAngle = newAngle * 0.1 + wheelAngle * 0.9;
I may have some signs swapped, this is off the top off my head and not tested.
Elva
  • 3,223
  • I really appreciate your help! Using wheels angles was my first attempt, i already have this information stored, so i'm already doing the transformation - but this is apparently not enough. Consider the case where: 1) the wheel is in a stable position, aligned with the rotation circumference after a clock-wise rotation - then, 2) you start to apply a ccw-rotation to the cart- the swivel should lead the wheel to perform an initial 180 degree ccw-rotation, which shall be adeguately tweened. Actually, i'm stuck with this problem... – deblocker Jun 15 '16 at 06:55
  • One trick this is missing is ensuring that angles wrap around nicely from -pi to +pi. It can also help to treat the wheel's pivot/attachment point to the cart as offset from the center of the wheel to help get that castor trailing effect - I show a version of that in this answer. – DMGregory Dec 21 '21 at 05:11
