Let's say you can do a heavy lift once, and that's your maximum strength. Then let's say you decrease that weight by half and do as many repetitions as you can until your muscles don't move anymore. This is also your maximum strength....
Beause if the one rep max gets bigger, then also the half of that one rep max increases.
Half 100 is smaller than half of 101. And if you can do more repetitions with one weight it means it's getting easier... And if lifting a weight is easier than before then you got stronger. My queation is, how is it even possible to find a situation where strength and endurance are not directly correlated?
One might say cardio, but the heart is a muscle too.
Are there any papers proving that one can increase their 1 rep maximum without also increasing their endurance in lower weights?
Say my bicep curl is 60 pounds for once but 30 pounds for twenty reps.... If suddently I become able to do twenty-two reps with 30 pounds, how is it possible that my one rep max didn't alsp increase? And vice versa.
Free
  • Quick notes, (I may not get the chance to give a detailed answer any time soon) muscle endurance partially relates to the energy pathways and an individual’s capacity to clear metabolites greatly contributes to endurance. Strength’s contribution to endurance lies in the relative effort given by the muscle, less relative effort results in less fatigue and less metabolic waste building up. The two concepts (strength and endurance) are interrelated and they both affect each other. However, it is entirely possible to train almost exclusively for one adaptation over the other. – JustSnilloc Jan 13 '21 at 15:18
Let's say you can do a heavy lift once, and that's your maximum strength. Then let's say you decrease that weight by half and do as many repetitions as you can until your muscles don't move anymore. This is also your maximum strength.... Beause if the one rep max gets bigger, then also the half of that one rep max increases.
You seem to be making the assumption that the number of repetitions one can do at a set fraction of their one-rep maximum is fixed. This is not a valid assumption.
Take for example a person who has a squat 1RM of 100kg, and let's assume they can do 20 reps at half their 1RM, 50kg. For them, doing a high load, low rep training program might increase their 1RM to 120kg, without granting them the ability to do 20 reps at half their new 1RM. They'd almost certainly be able to do more reps at 50kg than they could before, but that doesn't mean their new 20RM is 60kg. They might be able to do 25 reps at 50kg now, but only 18 at 60kg.
Or if they instead ran a low load, high rep training program, they might only increase their 1RM to 110kg, but now be able to do 25 reps at 55kg.
Because the limiting factors in 1RM strength are muscle size and neurological adaptations, whereas the limiting factors in strength-endurance are muscle size and the phosphagen and lactic-anaerobic energy systems. Both modes of training will increase muscle size, but high load, low rep training training will also improve neurological adaptations, while low load, high rep training will also improve anaerobic energy systems. So there's a lot of overlap, but the training effects of the two are not identical.
No, but there are papers showing that high-load training results in large increases in maximal strength with small increases in endurance, whereas low-load high-rep training results in small increases in maximal strength but larger increases in endurance.
Anderson, T., & Kearney, J. T. (1982). Effects of Three Resistance Training Programs on Muscular Strength And Absolute and Relative Endurance. Research Quarterly for Exercise and Sport, 53(1), 1–7. https://doi.org/10.1080/02701367.1982.10605218
Stone, William J., & Coulter, Scott P. (1994). Strength/Endurance Effects From Three Resistance Training Protocols With Women Journal of Strength and Conditioning Research. 8(4):231-234, November 1994. https://journals.lww.com/nsca-jscr/Abstract/1994/11000/Strength_Endurance_Effects_From_Three_Resistance.5.aspx
Your one rep max probably did increase, but not necessarily in exact proportion to your increase in endurance.
David Scarlett
  • 14,315
  • 23
  • 50
I don't know for weight lifting, but there is a chart from a well known book in cycle training that talks about the different zones of training and how they affect the body:enter image description here
You can see that in the most intense zone (7 in this chart), performance depends on hypertrophy of fast twitch fibers and neuromuscular (i.e., nervous system) power. In areas that are more about endurance (Zones 2 and 3), performance depends on oxygen intake, the body's ability to process lactate acid, the amount of mitochondria in muscles, the amount of slow twitch muscle, and the processing of the body's stored glycogen.
Since the body's ability to perform in these different intensities depends on different bodily systems, you cannot improve simply by doing one or the other.
Muscles consist of slow twitch and fast twitch muscle fibers. The slow twitch are weak but can work for a long time, whereas the fast twitch are strong but can only work for a short period.
If you train with few reps you get stronger but most of this increase in strength comes from the fast twitch muscle fibers. As mentioned these can only work for a short period, and therefore play no role in endurance activities.
When you use muscle fibers for a prolonged time eventually more and more of these will drop out (actually the motor units) over time due to problems with oxygenation, energy supply and removal of metabolic byproducts from cells. Training endurance will cause adaptions such as increased number of capillaries in the muscles that alleviate this problem and make you able to sustain a moderate force output for a long time. This will on the other hand not improve your max strength.
Also max strength is the product of the muscles ability to exert force and the brains ability to generate a strong enough electric signal to fire as many as possible fibers at the same time. When training for max strength one improves the brains ability to generate such a strong signal. This is the "sports" mode. However this ability is not used in endurance activities. Instead the brain rotates which muscle fibers are being used. This is the "economy" mode. This rotation of muscle fibers is also an ability, and it is being trained by endurance activities.
So no strength and endurance are not directly correlated, but training for one may help a bit with the other.
Andy
  • 3,717
someone who starts lifting weights cannot lift 100 kilos the first time. This is because the muscles are weak because they have not encountered this resistance before.
Muscle strength refers to the amount of force a muscle can produce with maximum effort. Muscle endurance is the ability of a muscle or group of muscles to apply force repeatedly over an extended period of time. my opinion is that strength cannot develop without endurance. First, the ability of the muscles to resist resistance must be developed, then the power will come out by itself. The simplest example of this is that we have difficulty lifting 10-20 kg when we start sports. Later, these weights start to seem like a piece of cake to us because the muscles now develop themselves against this resistance. Unfortunately, no one who is just starting out can lift 100 kilos all of a sudden.
https://sporium.net/dayaniklilik-antrenmani-nedir-nasil-yapilir/
https://fitnessprogramer.com
  • OP is looking for scientific data, your answer is based on personal experience, can you provide scientific papers to back your claim? – paradox Jan 14 '21 at 22:13
