For some reason, Projectile has stopped allowing me to add new projects.
When I add the project, it seems to work. But when I select the project with C-c p p I get the following error:
Not sure how to fix this.
Vinn
  • 293
Using the answer from here, they said.
I think your project is indeed considered a project by projectile only if you have a .git folder in it (did you forget to git init?). I'm not seeing one in your case. You can alternatively add a .projectile file instead. Everything in that folder containing the .projectile file and all subfolders will be considered part of the same project.
[edit] to add to this, it must be a git repository with a non-hidden file commited to it. For example a repo that only contained .file_to_satisfy_projectile in the git history would not be sufficient, but file_to_satisfy_projectile would be.
masukomi
  • 105
Hercislife
  • 72
