If you really mean use Convert
as the initial input then this is how:
(let* ((opts '("Convert" "Split"))
(sel (completing-read "Subset: " opts nil t "Convert")))
(message "SEL: %s" sel))
as the default value then this is how:
(sel (completing-read "Subset: " opts nil t nil nil "Convert")))
as both the initial input and the default value then this is how:
(sel (completing-read "Subset: " opts nil t "Convert" nil "Convert")))
In the initial-input (only) case Convert
is preinserted into the minibuffer, and the default, if you remove that preinserted input, is the empty string, ""
In the default (only) case Convert
is not inserted -- you use M-n
to insert it. And if you just RET
without inserting any text then you get Convert
In all three cases, just hitting RET
chooses Convert
. Convert
is an allowed completion because you decided that it belongs to opts
, which you pass as the allowed completions.
If you remove Convert
from opts
and change the t
value of arg REQUIRE-MATCH
to nil
, then Convert
isn't a completion but it is accepted as an input. Anything at all is accepted as an input, in this case.
It all depends on what you want. If you have a more specific question, please pose that separately.
completing-read
function. You can find that usingC-h f
. And, while typing thecompleting-read
form, the expected arguments are displayed in the echo area. Or do you mean something else? I am not sure what is your goal, but if you have only two options, you could also consider to use theuniversal argument
. – dalanicolai Jun 13 '22 at 22:31completing-read
I assume. – Dilna Jun 13 '22 at 23:05completing-read
, also not a shortcoming of the documentation. Just a limitation of our patience to read the function it's documentation :) – dalanicolai Jun 14 '22 at 06:03
