Is there a way to browse a flash USB drive formatted in Mac OS Extended (Journaled, Encrypted)
using Emacs 27 Dired?
After I Enter a password to unlock the disk “XYZ”.
I can browse the folders and the files just fine using Finder, but I prefer to operate with Emacs rather than Finder.
When I try to look (through Emacs Dired-mode
) at the Volume, I get Listing directory failed but ‘access-file’ worked
I am the owner of the volume:
drwxrwxr-x 7 calaf staff 306 Nov 18 12:14 XYZ
and so this does not seem to be a case of dr-xr-xr-x
permissions (where the files are readable if their names and paths are, but a directory listing isn't).
Edit
This appears to be not related to the disk formatting, but to whether a folder is backed up to iCloud.
It also appears to be related to a recent upgrade to Catalina, rather than to Emacs 27 (or, for that matter, to using sudo port install gnupg2
rather than port install gnupg
for Emacs ps-ccrypt
). But I don't have either Desktop or Documents connected to iCloud, and yet the same issue arises with both.
Can you clarify what this is all about?
~/Desktop
I get "Listing directory failed but ‘access-file’ worked". – Calaf Nov 20 '20 at 02:32
