As the examble like cookicutter, it have a read input in itself that we must type if we use it in normal terminal.
$> #comment: this is normal terminal emulator
$> cookiecutter $HOME/cookiecutter/script
$> enter script name: <we input here>
$> generate template....
Now I want to write a function that exec it from emacs ecosystem. I try:
(defun cookiecutter-el ()
  (interactive)
(if (not (file-exists-p (concat (getenv "HOME") "/" "cookiecutter/"))) (dired-create-directory (concat (getenv "HOME") "/" "cookiecutter/"))) (setq cookiecutter-choose (completing-read "PROMT> " (split-string-and-unquote (shell-command-to-string "ls -1 (getenv "HOME") "/cookiecutter/") "\n" ) )) (eshell-command (concat "cookiecutter " "/home/larva/cookiecutter/" cookiecutter-choose)))
or (call-process-shell-command) or something similar is not work. Because It only work with a process that have output or those process must be terminated. In case of cookiecutter, it requires we to input before it terminated the process.
As I remember, emacs-gdb multiwindow require we input from "input/output" window. I think emacs don't support deal with this case by default.
I can do easy thing like exec cookiecutter from terminal emulator, I just want to find out how things work
Kidman
