Is there a way in org-mode's HTML export to make it so that code blocks that have :tangle no
will appear differently? Even adding a different HTML class will do, as one can then probably add some CSS to alter their appearance (e.g. grey background or whatever).
Longer version / context:
I'm using org-mode
(and its org-babel
) to keep code and documentation together in a single file. Specifically, as in this question, I have
(require 'org)
(org-babel-load-file (expand-file-name "~/emacs/config/init.org"))
so that init.org
can generate both an init.el
file (for consumption by Emacs), and an init.html
file (for consumption by me, when I want to make sense of my config again). In this file, I have some sections that I don't want to be part of init.el
(e.g. either I decided against them, or they're simplified versions given first for understanding, before the “real” code, etc). For them, instead of something like
#+BEGIN_SRC emacs-lisp
(require 'cc-mode)
#+END_SRC
I have:
#+BEGIN_SRC emacs-lisp :tangle no
(require 'cc-mode)
#END_SRC
and everything works fine: the code no longer runs on startup, as it's no longer part of the generated init.el
. However, the code still shows up in init.html
(as I want it to) when I export from the org file, but unfortunately there's no longer any indication that this section is not going be tangled.
I imagine that in the HTML file, instead of
<div class="org-src-container">
<pre class="src src-emacs-lisp">
</pre>
</div>
if I could persuade org-mode / org-babel export to add another class, then I'd know how to solve the rest.
org-html-src-block
(inox-html.el
). Not sure how to tell it that something is a:tangle no
block... maybe it's already present insrc-block
, or can be passed ininfo
(wherever this function is called... not sure of that either). – ShreevatsaR Aug 24 '18 at 19:25
