I am running into problems creating and connecting to an Emacs daemon on RHEL 6. I am using Emacs 23.1.1.
The daemon starts correctly:
emacs --daemon=foo
Starting Emacs daemon.
… but when I try to launch a client against it I get:
$ emacsclient -f foo -t
emacsclient: connected to remote socket at 255.255.255.255
emacsclient: connect: Network is unreachable
Unable to start the daemon.
Another instance of Emacs is running the server, either as daemon or interactively.
You can use emacsclient to connect to that Emacs process.
Error: server did not start correctly
Error: Could not start the Emacs daemon
I tried to find the port Emacs listens to by way of lsof
$ ps aux | grep -i emacs | grep -v grep
mperdike 19396 0.3 0.4 259832 17596 ? Ss 18:21 0:00 emacs -nw --daemon=foo
$ lsof -Pan -p 19396 -i
… but as can be seen in the screen above lsof
didn't produce any output (maybe that's because I am not a sudoer).
emacsclient
bash script that looks under~/.emacs.d/server
and asks me which emacs server I wish to connect to. With the local (UNIX domain) sockets I get no files under~/.emacs.d/server
. Is there a way to discover which servers are running on local (UNIX domain) sockets from bash ? – Marcus Junius Brutus Oct 24 '16 at 17:49server-use-tcp
. If not the socket is found in the directory given byserver-socket-dir
. To list open unix sockets you can usess -lp | grep emacs
. – Uwe Koloska Oct 25 '16 at 12:18
