50
I have a dataset with 3 classes with the following items:
  • Class 1: 900 elements
  • Class 2: 15000 elements
  • Class 3: 800 elements
I need to predict class 1 and class 3, which signal important deviations from the norm. Class 2 is the default “normal” case which I don’t care about.
What kind of loss function would I use here? I was thinking of using CrossEntropyLoss, but since there is a class imbalance, this would need to be weighted I suppose? How does that work in practice? Like this (using PyTorch)?
summed = 900 + 15000 + 800
weight = torch.tensor([900, 15000, 800]) / summed
crit = nn.CrossEntropyLoss(weight=weight)
Or should the weight be inverted? i.e. 1 / weight?
Is this the right approach to begin with or are there other / better methods I could use?
Thanks
Muppet
  • 797
  • When you say: You can also use the smallest class as nominator, which gives 0.889, 0.053, and 1.0 respectively. This is only a re-scaling, the relative weights are the same. But this solution is in contradiction with the first one you gave, how does it work ? – Georges Matar Oct 05 '19 at 15:41
Cross-entropy is the go-to loss function for classification tasks, either balanced or imbalanced. It is the first choice when no preference is built from domain knowledge yet.
This would need to be weighted I suppose? How does that work in practice?
Yes. Weight of class $c$ is the size of largest class divided by the size of class $c$.
For example, If class 1 has 900, class 2 has 15000, and class 3 has 800 samples, then their weights would be 16.67, 1.0, and 18.75 respectively.
Yes, this is the right approach.
EDIT:
Thanks to @Muppet, we can also use class over-sampling, which is equivalent to using class weights. This is accomplished by WeightedRandomSampler in PyTorch, using the same aforementioned weights.
Esmailian
  • 9,312
  • 32
  • 48
    I just wanted to add that using WeightedRandomSampler from PyTorch also helped, in case someone else is looking at this. – Muppet Apr 02 '19 at 17:40
    When the labels are imbalanced, say 11 labels, one of them takes 17%, and others take 6-9%, Cross-entropy cannot learn that fast, at early stage, the loss focuses on learning the label which takes the largest proportion. – GoingMyWay Jun 04 '20 at 15:33
  • Just for completeness: There are also other/ more advanced approaches, like the one proposed here: https://arxiv.org/abs/1901.05555. You can find implementations here: https://paperswithcode.com/paper/class-balanced-loss-based-on-effective-number – rob Nov 25 '21 at 08:22
I am totaly agree with @Esmailian
def compute_pos_weights(cls_repr: torch.Tensor) -> torch.Tensor:
    total_weight = cls_repr.sum()
    weights = 1/torch.div(cls_repr, total_weight)
    # Standardize the weights
    return torch.div(weights, torch.min(weights))
tCot
  • 101
    As it’s currently written, your answer is unclear. Please [edit] to add additional details that will help others understand how this addresses the question asked. You can find more information on how to write good answers in the help center. – Community Jan 19 '23 at 17:47
