Based on the paper by Chen & Guestrin (2016) "XGBoost: A Scalable Tree Boosting System", XGBoost's "exact split finding algorithm enumerates over all the possible splits on all the features to find the best split" (page 3). Thus, my understanding was that XGBoost enumerates over all features and uses unique values of each feature as candidate split points to then choose the split value that maximizes the splitting criterion (gain).
Then, my question is why do the split values for float-type features chosen are often not one of the unique values for that feature? For example, for a certain feature in the data with floating point values, like so: 966.0, 1234.0, 2350.0, 4567.0 .... If Xgboost chooses to split on that feature, the split value can be, e.g. (feature < 1800.5), which is not one of the unique values for that feature, but is often the mid-point between two values.
Also, assuming no missing values in the data, for the ordinal type features, with the values like so: set(1, 2, 3, 4, 5, 6, 7, 8), declared as integers, how does XGBoost enumerate candidate split points? Does the algorithm treat that feature as categorical?
I've read a lot of good answers on the forum, like here and here, have gone thru xgboost documentation and tutorials, but they don't seem to elucidate on the specific procedure of enumerating candidate split points for exact greedy algorithm.
Could someone, perhaps, familiar with the source code could shed light on these questions?
tvl
  • 71
I dug into this a bit over at this answer, including a Colab notebook. I'll mostly refer you to that answer for the references, but I'll summarize here:
At some point in time, xgboost had different behavior for low-cardinality discrete features, splitting at the actual data values; whereas continuous features have always(?) split at midpoints between training data values. The current behavior though is to always split at midpoints, with no special treatment of discrete features. (Unordered categoricals now have some experimental handling, but that's an entirely different matter.)
In your quote from the paper:
"all possible splits" can be understood to mean splits of the training data into two pieces (left and right), and so doesn't need to mean anything about whether the actual feature values or some point between values is used.
Ben Reiniger
  • 11,770
  • 56
XGBoost's exact greedy split finding algorithm enumerates over all possible splits for each feature to find the best split. For floating-type features, the algorithm uses a histogram-based approximation to determine the candidate split points. This means that the split values chosen for floating-type features are not necessarily one of the unique values for that feature.
For ordinal-type features, the algorithm treats the feature as categorical and enumerates over all possible splits based on the unique values in that feature. This means that the split values for ordinal-type features will be one of the unique values for that feature.
Mohith7548
  • 492
The splitting criteria for float-type features is covered in paper in section "3.3 Weighted Quantile Sketch" and the Appendix.
Quantile sketch divides the data into weighted percentages and does the split based on that approximation.
The split value does not have to unique value in the feature because the algorithm uses approximations.
Brian Spiering
  • 21,136
  • 26
  • 109
  • The weighted quantile sketch is an alternative to the exact split-finding algorithm, so this doesn't answer the question. – Ben Reiniger Aug 28 '21 at 17:38
