Could someone please suggest how to remove local outliers from the dataframe? I have the code to detect the local outliers, but I need help removing them(setting these values to zero) in the dataframe. Any advice would be highly appreciated.
The code to detect the local outliers is below:
def printOutliers(series, window, scale= 1.96, print_outliers=False):
rolling_mean = series.rolling(window=window).mean()
#Print indices of outliers
if print_outliers:
    mae = mean_absolute_error(series[window:], rolling_mean[window:])#mean absolute error is a measure of difference between two continuous variables.
    deviation = 3*np.std(series[window:] - rolling_mean[window:])
    lower_bound = rolling_mean - (mae + scale * deviation)
    upper_bound = rolling_mean + (mae + scale * deviation)
    outliers_lower = series[series<lower_bound]
    outliers_upper = series[series>upper_bound]
    print("values beyond lower bound are: " +  "\n"  + str(outliers_lower))
    print("values beyond lower bound are: " + "\n" + str(outliers_upper))
printOutliers(df['Column1'].dropna(how='any'), 10, print_outliers=True)
natg
You could use this approach here:
# accept a dataframe, remove outliers, return cleaned data in a new dataframe
# see http://www.itl.nist.gov/div898/handbook/prc/section1/prc16.htm
def remove_outlier(df_in, col_name):
    q1 = df_in[col_name].quantile(0.25)
    q3 = df_in[col_name].quantile(0.75)
    iqr = q3-q1 #Interquartile range
    fence_low  = q1-1.5*iqr
    fence_high = q3+1.5*iqr
    df_out = df_in.loc[(df_in[col_name] > fence_low) & (df_in[col_name] < fence_high)]
    return df_out
sigmundojr
  • 56
