I would appreciate if you could let me know in the following example code:
from collections import Counter
from sklearn.datasets import make_classification
from sklearn.model_selection import train_test_split,StratifiedKFold,learning_curve,validation_curve,GridSearchCV
from sklearn.preprocessing import StandardScaler
from sklearn.linear_model import LogisticRegression
from sklearn.pipeline import Pipeline
from sklearn.metrics import classification_report
import numpy as np
def plot_learning_curve(train_sizes, train_scores, test_scores, title, alpha=0.1):
train_mean = np.mean(train_scores, axis=1)
train_std = np.std(train_scores, axis=1)
test_mean = np.mean(test_scores, axis=1)
test_std = np.std(test_scores, axis=1)
plt.plot(train_sizes, train_mean, label='train score', color='blue', marker='o')
plt.fill_between(train_sizes, train_mean + train_std,
train_mean - train_std, color='blue', alpha=alpha)
plt.plot(train_sizes, test_mean, label='test score', color='red', marker='o')
plt.fill_between(train_sizes, test_mean + test_std, test_mean - test_std, color='red', alpha=alpha)
plt.title(title)
plt.xlabel('Number of training points')
plt.ylabel('F-measure')
plt.grid(ls='--')
plt.legend(loc='best')
plt.show()
def plot_validation_curve(param_range, train_scores, test_scores, title, alpha=0.1):
plt.plot(param_range, train_mean, label='train score', color='blue', marker='o')
plt.fill_between(param_range, train_mean + train_std,
plt.plot(param_range, test_mean, label='test score', color='red', marker='o')
plt.fill_between(param_range, test_mean + test_std, test_mean - test_std, color='red', alpha=alpha)
plt.title(title)
plt.grid(ls='--')
plt.xlabel('Parameter value')
plt.show()
X, y = make_classification(n_classes=2, class_sep=2,weights=[0.9, 0.1], n_informative=3, n_redundant=1, flip_y=0, n_features=20, n_clusters_per_class=1, n_samples=1000, random_state=10)
print('Original dataset shape {}'.format(Counter(y)))
ln = X.shape
names = ["x%s" % i for i in range(1, ln[1] + 1)]
X_train, X_test, y_train, y_test = train_test_split(X, y,random_state=0)
st=StandardScaler()
rg = LogisticRegression(class_weight = { 0:1, 1:6.5 }, random_state = 42, solver = 'saga',max_iter=100,n_jobs=-1)
param_grid = {'clf__C': [0.001,0.01,0.1,0.002,0.02,0.005,0.0007,.0006,0.0005],
'clf__class_weight':[{ 0:1, 1:6 },{ 0:1, 1:4 },{ 0:1, 1:5.5 },{ 0:1, 1:4.5 },{ 0:1, 1:5 }]
pipeline = Pipeline(steps=[('scaler', st),
('clf', rg )])
cv=StratifiedKFold(n_splits=5,random_state=42)
rg_cv = GridSearchCV(pipeline, param_grid, cv=cv, scoring = 'f1')
rg_cv.fit(X_train, y_train)
print("Tuned rg best params: {}".format(rg_cv.best_params_))
ypred = rg_cv.predict(X_train)
print(classification_report(y_train, ypred))
print('######################')
ypred2 = rg_cv.predict(X_test)
print(classification_report(y_test, ypred2))
plt.figure(figsize=(9,6))
param_range1=[i / 10000.0 for i in range(1, 11)]
param_range2=[{0: 1, 1: 6}, {0: 1, 1: 4}, {0: 1, 1: 5.5}, {0: 1, 1: 4.5}, {0: 1, 1: 5}]
if __name__ == '__main__':
train_sizes, train_scores, test_scores = learning_curve(
estimator= rg_cv.best_estimator_ , X= X_train, y = y_train,
train_sizes=np.arange(0.1,1.1,0.1), cv= cv, scoring='f1', n_jobs= - 1)
plot_learning_curve(train_sizes, train_scores, test_scores, title='Learning curve for Logistic Regression')
train_scores, test_scores = validation_curve(
estimator=rg_cv.best_estimator_, X=X_train, y=y_train, param_name="clf__C", param_range=param_range1,
cv=cv, scoring="f1", n_jobs=-1)
plot_validation_curve(param_range1, train_scores, test_scores, title="Validation Curve for C", alpha=0.1)
estimator=rg_cv.best_estimator_, X=X_train, y=y_train, param_name="clf__class_weight", param_range=param_range2,
plot_validation_curve(param_range2, train_scores, test_scores, title="Validation Curve for class_weight", alpha=0.1)
Why when the best estimator of GridSearchCv is passed into the learning curve function, it prints all the previous print lines several times?
How to plot validation curve for class weight?
TypeError: float() argument must be a string or a number, not 'dict'
semicolon
at the end of your call.. – Aditya Mar 26 '18 at 02:09
