-1
When working with prediction problems, is there a need to consider the change in time or not?
For example, when trying to predict the price of a house, we just have the current features and the current price. The classification problem is to predict if the house price will be above a threshold or not. The regression problem is to predict the exact price.
Is there a need to have datasets with some time interval between them (for example X days or Y years) or we can predict with a dataset that was taken at a certain time? And in this case, is there a difference between classification and regression?
Thomas Lee
  • 155
  • It completely depends problem at hand.. Read here https://datascience.stackexchange.com/q/29006/35644 – Aditya Mar 16 '18 at 00:15
    @Aditya I can't see a relation between feature section and the above problem – Thomas Lee Mar 16 '18 at 00:44
  • I feel you opening question line says is there a need to consider time change... That comes under features. And yes you should consider them as it's natural formprices tongi up with time – Aditya Mar 16 '18 at 02:27
  • I agree that it completely depends on the problem, but I also agree that I don't see how that link is related to the question. This question is about model evaluation (downstream process), not feature engineering (upstream process). – David Marx Mar 16 '18 at 09:16
If you have some data that displays pattern of changing prices (or your target) over time, then sure, you have to consider the time change. This data will then become a time-series data, which has to be processed differently than normal data.
The problem of predicting prices at first-hand is regression, because the prices take continuous values. But you can convert it to classes according to your threshold. So in this case, (as far as I understand), there is no difference between regression and classification, as you are just putting numbers (prices) in different classes.
Hope it helps.
Please comment if something is not clear.
Ankit Seth
  • 1,821
  • 27
  • How to predict a house price with just one target (not time series)? For example, the only given price is in 2018
  • – Thomas Lee Mar 16 '18 at 12:13
  • Is seems to me that in the case of binary classification, we just need one dataset. – Thomas Lee Mar 16 '18 at 12:14
  • If you don't have data belonging to different time, then its not time-dependent. Then you should go with simple linear/polynomial regression method. – Ankit Seth Mar 16 '18 at 13:34
