Is it possible to solve every problem (solvable with turing machine) with only recursion ? If yes, which principles or theories assure this ? Thanks
Hi, im my life i solved some problems using recursion and i wanna know if exist some theorems that proves if is it possible to solve every problem (solvable with turing machine) with only recursion – Qwerto Feb 26 '18 at 10:29
Please specify what operations 'recursion' consists of and what other operations are allowed. For instance, many problems will be unable to be solved without some form of I/O (this can be implicit in your model, but this has to be specified). An example of what 'only recursion' can mean is 'no other control structures'. – Discrete lizard Feb 26 '18 at 10:50
What would "only recursion" mean? What are you forbidding? What operations are allowed? Please edit the question to clarify it -- don't leave clarifications in the comments, but edit the question so it is clear for someone who encounters it for the first time. We want questions to stand on their own so people don't have to read the comments. – D.W. Feb 26 '18 at 18:05
Can you define what it means to solve a problem "only" with recursion?
Would your definition allow an algorithm like this:
int foo(int n) {
if (n==1) return 1;
while(someCondition) {
do something
foo(n-1);
If your definition would wllow this, then it would be easy to transform every algorithm in such a recursive form (you could do all your calculations in the outermost function call and do nothing in the recursive calls).
- 91
- 6
1Surely, you mean "
if(someCondition) {...}
"? At the moment, your example contains both iteration (while
) and recursion. – David Richerby Feb 26 '18 at 13:02
A set $A$ is computable (like in Turing machines) iff its characteristic function $$\chi_A(x) = \begin{cases}1, & x \in A\\ 0, & x \notin A\end{cases}$$ is recursive. The class of recursive functions (sometimes referred to as $\mu$-recursive functions) is the smallest class that contains all constant functions, successor function, projection, and is closed under substitution, primitive recursion and minimization.
So yes, every computable function is recursive w.r.t. to the definition above.
- 1,621
- 9
- 18
Why the recursion is so versatile (speaking in practice) so as every problem can be converted in a recursion problem ? – Qwerto Feb 26 '18 at 11:49
2Although this has been accepted, it's not clear to me that it actually answers the question. The question, to me, seems to be about recursion in the sense of programming languages (functions calling themselves), not in the sense of recursion theory. Indeed, in terms of computability, the words "recursive" and "computable [by a Turing machine]" are taken as synonymous, but there's no meaningful recursion in Turing machines. – David Richerby Feb 26 '18 at 12:38
You say true things, but there is no reasoning whatsoever. You say "so yes", but where does the "so" come from? – Raphael Feb 26 '18 at 12:38
1@Raphael Isn't the duplicate question actually going the other way? (Being able to replace all recursions with iteration doesn't necessarily imply that you can replace all iteration with recursion, which is what this question is asking.) – David Richerby Feb 26 '18 at 12:42
I am not quite sure in which direction you want to go with that question @Qwerto. In theory, the story goes like "look at some program, it can be encoded in some number and then be simulated by encoding each step the program does". In terms of programming languages the steps are quite the same. It is not too hard to eliminate the while-loop from e.g. C by doing some simulation of each iteration with recursion. – ttnick Feb 26 '18 at 12:45
@DavidRicherby Hm, true. Don't we have a question for the other direction around? Something about Turing-completeness of lambda calculus or $\mu$-recursion? – Raphael Feb 26 '18 at 12:46
@Raphael I agree that the "so" comes from nowhere here. For further explanation, one should probably properly show how the recusrive functions simulate any Turing machine which is quite tedious but I could do that. However, as David mentioned that this post is more about the practical view in programming languages. So some comparison between functional programming languages and languages with iterations would be more suitable? – ttnick Feb 26 '18 at 13:04
It's your answer, do what you feel is best. As long as you actually answer the question. ;) – Raphael Feb 26 '18 at 17:48
