In my limited exposure, it appears that "successful" machine learning algorithms tend to have very large VC dimension. For example, XGBoost is famous for being used to win the Higgs Boson Kaggle competition, and Deep Learning has made many headlines. Both algorithm paradigms are based on models that can be scaled to shatter any dataset, and can incorporate boosting which increases VC dimension.
According to VC dimension analysis, a large dimension is supposedly a bad thing, it allows models to overfit or memorize the data instead of generalize. For example, if my model shatters every dataset, e.g. a rectangle around every point, then it cannot be extrapolated outside the dataset. My grid of rectangles tells me nothing about points outside the grid. The larger the VC dimension, the more likely the model will shatter a dataset instead of generalizing, and thus once exposed to new data outside the training dataset, it will perform badly.
Example of algorithm shattering dataset.
Back to the original point, many of the most "successful" machine learning algorithms have this common trend of having a large VC dimension. Yet, according to machine learning theory this is a bad thing.
So, I am left confused with this significant discrepancy between theory and practice. I know the saying "In theory there is no difference between theory and practice, in practice there is" and practitioners tend to brush aside such discrepancies if they get the results they want. A similar question was asked regarding Deep Learning, and the consensus was that it did have large VC dimension, but that doesn't matter because it scores very well on benchmark datasets.
But, it is also said "there is nothing more practical than good theory." Which suggests such a large discrepancy has a significance for practical application.
My question then, is it true that the only thing that really matters is low error scores on test datasets, even when the theoretical analysis of the algorithm says it will generalize poorly? Is overfitting and memorizing instead of generalizing not that big of a deal in practice if we have hundreds of billions of samples? Is there a known reason why the theory does not matter in practice? What is the point of the theory, then?
Or, are there important cases where a very large VC dimension can come back to bite me, even if my model has great scores? In what real world scenario is low error and large VCD a bad thing, even with hundreds of billions of samples in the training data?
yters
  • 1,417
When left with a discrepancy between theory and data, data is king. Theory is intended to be predictive -- to make predictions about the world -- but when it fails to predict what we actually observe and experience, when its predictions disagree with our experience, then there is obviously something lacking in the theory.
In this case, VC theory just isn't adequate to understand modern practice in machine learning.
Unfortunately, VC theory ignores methods like regularization. Regularization is widely used in practice, so that's a pretty important gap in VC theory. VC theory counts the number (size, dimension) of possible models, and treats all of them as "equally valid/likely".
When we train a model with regularization, we depart from that paradigm. Regularization implicitly encodes the assumption that "all else being equal, simpler models (explanations) are more likely to be correct". In other words, regularization is essentially an application of Occam's Razor. In effect, regularization encodes some kind of prior on the distribution of likely models: not all models are equally likely; simpler models are more likely to be right. Classical VC theory doesn't take that into account, and thus can't make useful predictions about the behavior of machine learning methods that use regularization.
Practitioners aren't "brushing aside" the theory. Rather, VC dimension simply doesn't seem to be super-relevant to practice. It is too limited.
It's still an open question to understand why techniques like deep learning work so well. VC dimension was an early attempt to understand machine learning -- a powerful, beautiful, valiant attempt, one that may still be of some interest -- but ultimately one that doesn't seem to give us the whole picture, perhaps partly because it does not account for things like regularization and our priors on the model.
D.W.
  • 159,275
  • 227
  • 470
    To add on to that, the optimization in practice can select a model with lower VC dimension. While the model can scale to high VC dimensions, by choosing simpler models, we're often giving preference to those which generalize better - for example, VC-dimension bounds for SVM scale inversely with the size of the (error-free) margin. – MotiNK May 15 '17 at 07:26
    The notion of regularization is captured by VC theory, as a simpler hypothesis class may have lower VC dimension. – Ariel May 15 '17 at 08:42
  • @Ariel, I don't see how; can you elaborate? The class of all models might have large VC dimension; but regularization makes some models are more favored over others. I.e., VC dimension calculates the dimension of the set of all models with a non-zero prior probability. With regularization, the prior of some models can be much higher than others. So, if we considered only the set of models with a large prior prob., the VC dimension might be small, but if we consider all models, VC dimension is large. Regularization preferentially picks the former, but falls back to the latter if needed. – D.W. May 15 '17 at 16:19
  • Given a sequence of classes $\mathcal{H}_1\subseteq\mathcal{H}_2\subseteq...$ where the VC dimension of $\mathcal{H}_i$ is $i$, set your priors, the probabilities of finding a consistent hypothesis from $\mathcal{H}_k$, to be $p_k$ (you can choose the sequence $p_k$ anyway you like as long as it sums to one). You can now bound the generalization error of a learning algorithm for $\bigcup\limits_i \mathcal{H}_i$ in terms of the priors. This bound is distribution free but of course depends on the target concept. – Ariel May 15 '17 at 16:37
  • This is described in theorem 2.1 of this paper http://ieeexplore.ieee.org/stamp/stamp.jsp?arnumber=705570, "Structural Risk Minimization Over Data-Dependent Hierarchies", by John Shawe-Taylor et al. – Ariel May 15 '17 at 16:38
  • @Ariel, Cool! I wasn't aware of that. That's much closer to what we need. I presume we're still pretty far from being able to apply that to deep learning (it requires a way to calculate the VC dimension of all models whose regularization penalty is $\le c$, and I'm not sure how one would do that). – D.W. May 15 '17 at 17:08
  • "VC dimension doesn't seem to be super-relevant to practice" not true, it's not relevant for understanding deep learning but it has many practical uses in PAC learning. For example VC dimension can tell you that if you want to approximately find a median you can sample log(1/delta)/epsilon^2 items and find the median there and you'd have an error of (1+-epsilon) on the percentile. VC dimension have many practical applications including finding outliers in a dataset or shrinking a dataset for some problems and many other uses. So it has uses just not in deep learning. – Tomer Wolberg Dec 14 '20 at 12:27
To expand my point in your previous post, VC theory (and PAC learning) is a WORST CASE theory. The requirement to handle any possible distribution on the data is too restrictive for real life applications. If $\mathcal{C}\subseteq 2^\mathcal{X}$ is a concept class with high VC dimension, there might still be an algorithm that achieves small generalization error relative to, say, the uniform distribution on $\mathcal{X}$. The question now is, whether the uniform distribution is something we can expect when treating examples from $\mathcal{X}$ (if for example I'm trying to separate pictures of dogs from pictures of cats, I wouldn't expect the uniform distribution on images to be meaningful here).
"Is it true that the only thing that really matters is low error scores on test datasets, even when the theoretical analysis of the algorithm says it will generalize poorly?"
Definitely not. It is useful to have an algorithm that seems to work, but you would be even happier if you could provide formal guarantees (error lower bound). We need some non worst case theory that finds the right conditions under which the algorithms you mentioned are indeed successful (in some formal sense), and argues why those conditions are satisfied in the cases where we witness empirical success. This will give us better understanding in general, and perhaps carve the way towards even better learning algorithms.
Ariel
  • 13,369
  • 38
  • Agreed. But in this case, the worst case is worst case over data distributions (i.e., over models). When we're using regularization, we're effectively saying that not all data distributions are equally likely (not all models are equally likely) -- in other words, it's usually because we care less about the worst case and more about the average case. VC theory doesn't have much to say about the average case; and the average case seems to be something people care about in practice. – D.W. May 15 '17 at 16:21
  • @Ariel, building on the second part of your answer, and address my last set of questions, in which scenarios would it be bad to have a model with low error rates on the test data, but it is overfitting/memorizing instead of generalizing (as perhaps implied by a high VC dimension)? If you answer this, I'll accept your answer. – yters May 16 '17 at 01:52
  • Simplest thing, given a set of labeled samples $(x_1,y_1),...,(x_n,y_n)\subseteq\mathcal{X}\times{0,1}$, consider the memorizing learner which outputs a function $f$ which is zero outside of $x_1,...,x_m$, and for all $x\in{x_1,...,x_m}$ it satisfies $f(x_i)=y_i$. This learner always achieves zero error on the training set, but is obviously overfitting (in this case our model is too complicated, since we let our hypothesis class be the entire $2^\mathcal{X}$, which has infinite VC dimension when $\mathcal{X}$ is infinite). – Ariel May 16 '17 at 21:30
  • Sorry, I meant it has low error on samples it was not trained on. – yters May 18 '17 at 02:09
