Let $M_0$, $M_1$, $M_2$,..., be an effective enumeration of all Turing machines. Which of the following problems is (are) decidable ?
  • Given a natural number $N$, does $M_N$ starting with an empty tape halts in fewer than $N$ steps ?
  • Given a natural number $N$, does $M_N$ starting with an empty tape halts after at least $N$ steps?
  • Given a natural number $N$, does $M_N$ starting with an empty tape halts in exactly $N$ steps?
I've looked some of these similar problems like :-
Prove that this language is decidable or undecidable
Is the set of Turing machines which stop in at most 50 steps on all inputs, decideable?
I've got some idea that $TM$ problems related to $N$ steps, only the cells upto $N$ are significant.
Such problems are decidable, however long input we take.
Hence, I come to the conclusion that $1$st part of my problem will be decidable similar to the reasoning as given above.
Similarly, for $3$rd part, if we check $N$th cell we can say $Y/N$ hence Decidable.
But, I am stuck in $2$nd part.
(What I think is that upto $N$th cell we can check if it halted, making it semidecidable otherwise it will definitely halt after the $N$th cell. Hence, I think it is also Decidable).
Please let me know how much correct progress I made. I don't have solutions for these questions. Need some confirmation ?
Garrick
  • 462
  • 22
You can simulate a given Turing machine to a given number of steps. This allows you to decide Problem 1 and Problem 3, by running $M_N$ on the empty type for $N$ steps (or fewer, if it halts earlier).
Regarding Problem 2, assuming that $N$ is in the language if
  1. $M_N$ halts on the empty tape, and
  2. $M_N$ doesn't halt within the first $N$ steps,
then you can use this language to solve the halting problem (using the same effective enumeration). Given $N$, in order to determine whether $M_N$ halts on the empty tape:
  1. Run $M_N$ for $N$ steps. If it halts, answer Yes.
  2. Otherwise, use Problem 2 to determine whether $M_N$ halts on the empty tape, but not within the first $N$ steps.
Hence Problem 2 is undecidable.
Yuval Filmus
  • 276,994
  • 27
  • 311
  • 503
