Let $X$ and $Y$ be problems, and let $X \le_p Y$. Is it true that \begin{equation} Y \in NP \rightarrow X \in NP\ ? \end{equation}
I do mean $NP$ here, not $NP$-complete or $NP$-hard.
The solution is simple if the reduction from $X$ to $Y$ transforms an instance of $X$ to an instance of $Y$; to verify that a solution to $X$ is correct, we could transform it to an instance of $Y$ and then verify that the transformed instance is a solution to $Y$.
All we know from $X \le_p Y$, though, is that you can solve $X$ with a polynomial number of solutions to $Y$; we're not guaranteed a simple one-to-one transformation.
I suspect that \begin{equation} Y \in NP \rightarrow X \in NP \end{equation} is true for all $X,Y$ such that $X \le_p Y$, but I would like confirmation, and I would like to know how to prove it.
oneateach
  • 53
The answer depends on what you mean by the notation $\le_p$.
  • If $\le_p$ refers to a Karp reduction (i.e., a many-one reduction), then the answer is "Yes". It follows from the definition of NP. See What is the definition of P, NP, NP-complete and NP-hard? to learn more.
  • Assuming that $\le_p$ refers to a Cook reduction (also known as a polynomial-time Turing reduction), then the answer is "We don't know for sure, but we think not".
    In particular, let $X$ be the problem TAUTOLOGY, and $Y$ be the problem SAT. Then $X \le_p Y$ (we can transform an instance of TAUTOLOGY to an instance of SAT; if you then flip the answer from an algorithm to solve SAT, the result will be the answer to TAUTOLOGY). We know that SAT is in NP. However $X$ is co-NP-complete, so $X$ is not likely to be in NP: if $X$ is in NP, then it follows that NP = co-NP, which would be a surprise. While we can't prove NP $\ne$ co-NP, many/most complexity theorists expect that NP $\ne$ co-NP is true, and from that it would follow that the answer to your question is "No" -- assuming you are referring to Cook reductions.
To learn more about the difference between these two types of reductions and why both notions exist, take a look at the following questions:
D.W.
  • 159,275
  • 227
  • 470
