Do "machine code" and "byte code" terms refer to the available instruction set to the CPU and virtual CPU and their encoding (the language specification) or do they refer to the "encoding" of the current program's instructions after compilation?
The definitions I found in wikipedia seem to lean towards the notion of "instruction set":
Both are sequence of instructions encoded as binary data. The difference being that "Machine code" is executed by the CPU whereas "byte code" is executed by a software (which itself is made up of machine code and executed by CPU).
- 628
- 3
- 12
Machine code is the set of machine instructions that make up the program. For instance, in ARM, this would be instructions like LDR, ADD, SUB, etc... Byte code is the code after compilation and is in bits. The format is usually 1-2 bytes representing the instruction and then more bytes representing the params passed into the instruction.
Note: there are many variations to this definition. Machine code to some may mean the hexadecimal representation of the code. It's definitely subjective.
Edit: When you open a file that has machine code inside it, it will have assembly instructions such as ADD, SUB, MUL, etc. Differs for different architectures. When you open a file with byte code, you will just a long list of just bits.
I think machine code and byte code are languages in their own. Compilation translates the source code from a high language to a lower level language (byte code or machine code).
- 133
- 1
- 4
00110101 10010100
, which I just randomly inputted, but that could meanADD $r1 $r2 $r3
in machine code (add registry_1 to registry_2 and store the result in registry_3). – ArianJM May 13 '16 at 08:20
