Would my complexity for the whole code be still maintained in $O(n \log n)$?
Let's check where we're coming from: Insertion Sort runs in time $\Theta(n^2)$ (worst and average case) if you implement findInsertionPosition
(fIP
) with a simple loop that scans the array.
Second, let's check what we can possible achieve. Assume that fIP
runs in time $O(1)$. We still get $\Theta(n^2)$ since insert
alone takes times linear in i
in each iteration (worst and average case), adding up to $\Theta(n^2)$.
Third, why use a tree? You can easily achieve running-time logarithmic in i
for fIP
(for a total of something in $\Theta(n \log n)$) by using binary search. That would still be dominated by the cumulative cost of insert
, of course.
If you did use a tree, it would make the most sense to not throw it away between iterations; fIP
would be obsolete. You would effectively have sorting by creating a search tree (which we don't really call Insertion Sort) but, yes, that would have running-time in $\Theta(n \log n)$, provided you use a balanced search tree.
In summary, no, it does not make sense to try and tweak Insertion Sort by using search trees.
findInsertPosition
operates on the already sorted part of the array! – Raphael May 24 '16 at 10:32
