Let $G=(V,E)$ be some directed graph where every node $v_i$, except for the source $s$ and sink $t$, has an in-edge $(s,v_i)$ and an out-edge $(v_i,t)$.
To compute the desired flow, we can reduce the problem to a new directed graph $G'=(V',E')$, where every node of the original Graph, except for $s$ and $t$, is replaced by two new nodes $v_i'$ and $v_i''$. The source is now connected to $v_i'$ and the sink to $v_i''$. Thus, we have new edges $(s,v_i')$ and $(v_i'',t)$. Furthermore, we connect every $v_i''$ with the corresponding $v_i'$ via an edge $(v_i'',v_i')$ of very high capacity. Finally, we add an edge $(v_i',v_j'')$ for every edge $(v_i,v_j)$ of the original graph. The capacity of every edge in $G'$ is equal to its counterpart in $G$, except for the edges $(v_i'',v_i')$, wich correspond to nodes in $G$ and therefore have arbitrary high capacity.
Note that flow that enters $v_i'$ via the source can not directly escape to the sink but must traverse an edge $(v_i',v_j'')$ to another vertex $v_j''$ first. From $v_j''$ the flow can either go to the sink, or continue onwards via $v_j'$. Thus, by computing a maximum flow in $G'$ we obtain a solution for $G$ where all flow that leaves the sink must traverse at least three edges before it reaches the sink.
In my solution: I built a graph, in which a connection between two numbers is established when there is a divisibility between those numbers. Then, I need to run the modified max flow method that I explained.
– beginner1010 Oct 16 '15 at 03:55
