I'm having trouble with this problem as I haven't discovered a good way to determine the power of a Turing machine. I was under the impression that if a Turing machine can perform the same actions and satifies unrestricted access to unlimited memory they're all pretty much equivalent. Such as multiple tapes and nondeterministic Turing machines.
I am to determine if a and b are equal, more powerful or less powerful then a single-tape Turing machine. Where do I start?
a) A Turing Machine that can only make moves to the right and never left.
b) A Turing Machine that can move right one space or move left two spaces.
David Richerby
  • 81,689
  • 26
  • 141
  • 235
Yawn
  • 101
Hint 1: So your first step should be to determine whether a and b have, or can obtain, unrestricted access to unlimited memory.
Hint 2: If yes, then try to emulate the missing pieces of your preferred Turing machine model.
Hint 3: If no, then try to show that the halting problem (with empty tape as input) is decidable.
Thomas Klimpel
  • 5,380
  • 27
  • 66
  • Regarding hint 3, you should be more precise as to what halting problem you are referring to. I mean is it the halting problem for standard TM or for the mutilated TM of the question. – babou May 18 '15 at 23:39
