I just learned that when we have a polynomial algorithm for NP-complete problems, it is possible to use that algorithm to solve all NP problems.
So, the question is how we then distinguish non-NP-complete NP problems from NP-complete problems? It seems that all these problems will have a polynomial algorithm to convert into other problems...
Raphael
  • 72,336
  • 29
  • 179
  • 389
Zat Mack
  • 249
To provide the flip side of 042's answer: it's important to understand that if $P=NP$ then every problem in $NP$ is $NP$-complete (caveat: under the usual poly-time reductions): $NP$-complete simply means 'every problem within $NP$ can be solved in polynomial time with an oracle for this problem'. But if every problem in $NP$ can be solved in polynomial time—that is, if $P=NP$—then the second part of that statement is vacuous.
On the other hand, if $P\neq NP$ then it's known that the problems that are in $NP$ but not in $P$ have a very rich structure - in particular, there have to be 'intermediate' problems that aren't in $P$ but also aren't $NP$-complete, and in fact an infinite number of distinct ones (that is, such that at least one can't be reduced to the other). For more details on this result (Ladner's Theorem), you might start with Lance Fortnow's notes on the topic.
Juho
  • 22,554
  • 62
  • 115
Steven Stadnicki
  • 2,509
  • 24
Not really. For instance, the Graph isomorphism problem is believed not to be in P, but on the other hand not being NP-complete (and is obviously in NP). Moreover, also all problems in P (that are also in NP) are not NP-complete, if $P \neq NP$. However, to my knowledge, all of these are mere conjectures, since the answer would solve P vs. NP.
042
  • 696
