I have started reading on algorithmic complexity for my thesis work. Already have studied on Polynomial time reducibility, NP-Complete, NP-Hard. Now trying to prove NP completeness of some of the classical problems. I have started with 3-SAT problem.
3-SAT problem — was shown to be NP-complete:
Input: A boolean Formula F in CNF where each clause contains at most three variables.
Question: Is that formula satisfiable?
Show now that the simple 3-SAT problem is also NP-complete:
Input: A boolean Formula F in CNF where each clause contains at most three variables and only clauses of length two may contain negated variables.
Can any please explain the main idea? Thank you in advance.
vessilli
Main idea: For each variable $x_i$ introduce a new variable $y_i$ and add a new clause $(\lnot x_i, \lnot y_i)$. Replace each occurence of $\lnot x_i$ in the original clauses by $y_i$.
The new clauses ensure that $y_i$ can be set to true if and only if $x_i$ is false. Thus we neither add nor remove satisfying assignments for the original clauses, while the new clauses can always be satisfied.
FrankW
  • 6,589
  • 26
  • 42
  • Thank you. Seems I have got some idea. Is there any way to reduce to graph problem? – vessilli May 06 '14 at 13:02
    Any NP-complete problem can be reduced to any other NP-complete problem. The question is just how complex the reduction function will get. – FrankW May 06 '14 at 13:05
