Consider the $k$-path problem: given a graph $G$ and an integer $k$, is there a simple path of length $k$ in $G$? To solve $k$-path, it suffices to find two paths of length $k/2$ and a vertex $v$ s.t. the paths only intersect in $v$. In general, such algorithms are known as "meet in the middle", or "split and list". Basically, split the problem into two or more parts, enumerate all possible solutions for the smaller parts, and finally combine them to a solution.
Horowitz and Sahni give the classical example for subset-sum (given a list of $n$ integers, is there a sublist whose elements sum up to $0$?). First, split the list into two parts of length $n/2$. For both parts, enumerate all possible $2^{n/2}$ sums. Using sorting and binary search, check if there are two sublists that sum up to zero. In general, such an algorithm gives you a halved exponential dependence on the input size. There are some more examples of this too, for starters you could check out [1].
Also, to add to D.W.'s answer, divide-and-conquer also seems to satisfy your requirements. More specifically, look into graph decompositions. A classical one is the Lipton-Tarjan planar separator theorem, which leads to efficient divide-and-conquer algorithms on planar graphs. There are plenty of other separator theorems and decompositions out there too. One that you see often for directed graphs is a modular decomposition.
[1] Fomin, Fedor V., and Dieter Kratsch. Exact exponential algorithms. Springer, 2010.
