We understand the exponential function to constantly grow, which we consider bad for a problem. By constantly growing I mean the ratio $\frac{f(n+1)}{f(n)}$ never tends to 1, where $f(n)$ is the exponential function.
However, when this ratio tends to 1, we can roughly say that as problem size increases by a small amount say O(1), then the time taken does not change by a large amount. Then why did we choose polynomials as a natural measure of easiness? Why don't we want the ratio $\frac{f(n+c)}{f(n)}$ of the time complexity to tend to 1, when $n \rightarrow \infty$. Note that $c = O(1)$ is any positive constant.
    This statement When we say that a problem takes exponentially long time, what we mean is that as we tweak the input parameters a little then the problem takes more time by a 'constant factor' sounds very inaccurate or meaningless. Can you rephrase what you mean? – JimN May 08 '23 at 22:27
  • I'm having a hard time understanding what your question is. Perhaps one of the challenges is that I don't understand what you are imagining as the alternative. I suspect that the questions marked as 'duplicate' might answer your question; or might give you a bunch of additional information might help you formulate more clearly what you are asking. I suggest reviewing the material there, and then if that doesn't answer your question, use that background to help you more clearly state your question (either by [edit]ing this question, or posting a new question). – D.W. May 09 '23 at 00:02
  • If you do ask a new question or edit this one, I suggest trying to specify more precisely and in more detail what you are imagining as an alternative definition of 'easiness'. You might also review what are the good properties of "polynomial time" listed in the linked questions, and then analyze whether your alternative definition has those good properties or not, and update your question to summarize what your conclusions on that are. – D.W. May 09 '23 at 00:03
  • When the time is polynomial, doubling the size of the input multiplies the time by a power of 2. When it is exponential, the new time is raised to a power. E.g. n³ makes 100000 turn to 800000, while 3^n makes 100000 turn to 10000000000. Tripling the size, 100000 becomes 2700000 vs. 1000000000000000. –  May 09 '23 at 07:57
