Firstly, I've tried assuming $L$ is regular and find a contradiction with help of the pumping lemma's 3 conditions, I was not able to get to a contradiction.
I've tried thinking of a word $z\in \{0,1\}^*$ to attach to $wv^i$ and $wv^j$ for some $i\neq j$, and to combine that with the pumping lemma's $xy^2z\in L, k\geq 1$ yet I got stuck on the way.
I'm looking for a direction of thought, a colleague suggested looking at the example word $10000000110000000$ , yet I cant see the how this example promotes what I'm trying to prove.
Aishgadol
  • 355
This language is regular. Denote $L = \{wvw\mid v,w\in\{0,1\}^*\}$.
I claim $L = \{0,1\}^*$. Indeed, the inclusion $\subseteq$ is clear. Conversely, let $u\in \{0,1\}^*$. Then $u = \varepsilon u\varepsilon \in L$.
Nathaniel
  • 15,071
  • 27
  • 52
  • Apologizes, I've forgot to mention the fact that $\epsilon \notin L$ I've also saw how it is regular when $\epsilon \in L$. – Aishgadol Mar 25 '23 at 10:07
  • What you say makes no sense: the language ${wvw\mid v,w\in{0,1}^*}$ is uniquely defined and it contains $\varepsilon$. – Nathaniel Mar 25 '23 at 10:11
  • Even if you consider $L = {wvw\mid v,w\in{0,1}^*}\setminus{\varepsilon}$, it is still regular, because regular languages are closed under set difference. – Nathaniel Mar 25 '23 at 10:13
  • double apologizes, it was my misunderstanding of the instructions I was given.
    after further clarifications from my instructor, instead of $\epsilon \notin L$, what I've meant is that the $w$ in $w,v\in {0,1}^*$ satisfies $w\neq \epsilon $
    – Aishgadol Mar 25 '23 at 10:29
  • Then just write $L = {wvw\mid v\in {0,1}^*, w\in {0,1}^+}$ so that there is no ambiguity. – Nathaniel Mar 25 '23 at 10:52
  • I see, I can also understand this notation. Thank you for this clarification. – Aishgadol Mar 25 '23 at 10:56
-1
Of course it is regular, because it contains the complete set {0,1}*.
Note: This was the correct answer to the question before it was edited.
gnasher729
  • 29,996
  • 34
  • 54
