As the title says: are there problems in $\mathbf{NP}$ that do not reduce in polynomial time to any problem in $\mathbf{NP}$?
Juho
  • 22,554
  • 62
  • 115
Fabio
    Only NPC (NP Complete) problems have such property they're reducible to each other in polynomial time, and a solution can be verified in polynomial time – ShAr Sep 11 '21 at 11:38
I understand the question as asking for the truth value of the proposition $\exists A \in \mathsf{NP}, \forall B \in \mathsf{NP}, A \not\le_p B$, where $\le_p$ denotes Karp reducibility.
Then the answer is no since, $\forall A \in \mathsf{B}$ we can pick $B=A$ and the choose the identity function as the Karp reduction from $A$ to $B$. In other words every problem in $\mathsf{NP}$ is Karp-reducible to itself.
Even if you want $A$ and $B$ to be distinct then the answer is still no. Formally, we want to know the truth value of $\exists A \in \mathsf{NP}, \forall B \in \mathsf{NP} \setminus \{A\}, A \not\le_p B$.
Indeed, for $\forall A \in \mathsf{NP}$, there exists some $B \in \mathsf{NP} \setminus \{A\}$ such that $A \le_p B$. Let $\sigma \in \Sigma$. An example of such $B$ is $\{ \sigma x \mid x \in A \}$, and the corresponding Karp reduction is $f(x) = \sigma x$.
Steven
  • 29,419
  • 28
  • 49
    I think your last sentence is backwards? The empty language is reducible to any non trivial language (by a reduction that always gives a constant false instance), but no non-trivial language is reducible to the empty language. – Mjiig Sep 12 '21 at 00:27
    I take it that in the first paragraph of your answer, you interpret the “any” from the question as “some”, and in the second paragraph, you interpret it as “all”? That’s kind of confusing. – Emil Jeřábek Sep 12 '21 at 11:48
  • That is, the answer does not change if you require the two problems to be distinct: just like every problem in NP is reducible to itself, every problem in NP is also reducible to a different problem in NP. – Emil Jeřábek Sep 12 '21 at 11:57
    @EmilJeřábek. Thank you! I got turned around in the second part of my answer. I revised it now. Just to be clear I understand the question as determining the truth value of: $\exists A \in \mathsf{NP}, \forall B \in \mathsf{NP}, A \not\le_p B$. Then, since we can pick $A=B$, the answer is "no". If we cannot pick $A=B$ then we are interested in the truth value of $\exists A \in \mathsf{NP}, \forall B \in \mathsf{NP} \setminus {A}, A \not\le_p B$. I also made the answer unambigous by removing occurrences to "any" and "all" and using formal notation instead. – Steven Sep 12 '21 at 12:41
The definition of the class NP-hard is that a problem is NP-hard if every problem in NP can be reduced to it in polynomial time.
The definition of the class NP-complete is just the problems that are NP-hard which are also themselves members of NP.
Therefore, since there exist members of NP-complete, the answer to your question is no, there are no problems in NP which cannot be reduced to any other problem in NP in polynomial.
In fact you can pick any one of those NP-complete problems, and there is no NP problem that cannot be reduced to that single problem of your choice.
Ben
  • 1,684
  • @Steven I didn't say there are no problems which cannot be reduced to every problem in NP, I said there are no problems which cannot be reduced to any problem in NP. They can all be reduced to SAT, for example. Do you think the OP meant every rather than any? – Ben Sep 12 '21 at 10:57
  • I see! No, I think of meant it exactly the way you interpreted it. Please disregard my previous comment. – Steven Sep 12 '21 at 12:47
-4
Only NPC (NP-Complete) problems have such property they're reducible to each other in polynomial time, and a solution can be verified in polynomial time.
-For example, how can you transform a sorting instance into a Minimum Spanning Tree instance (both in P)?! Doesn't even make sense
You can search and find huge material on NPC, however this can give you a brief on the big picture
https://youtu.be/EeACNt50Wf4
A clarifying Venn diagram
Sometimes NPC are called the Hardest Problems as compared to those in NP-Hard
Remarks:
1-I removed the medium Venn diagram, I'm very sorry it contained wrong info, factorization, primality are considered NP-Hard in the no. of bits in the number; here is an example of a problem (IsPrime?) where verifying the correctness of a solution have the same complexity as finding the solution
2- While I was searching for a Venn diagram image to put, I found there are previous answers in the group
How can I use the NP complexity Venn diagram to quickly see which class of NP problem can be poly reducible to another class?
What is the definition of P, NP, NP-complete and NP-hard?
enter image description here From MIT lecture 2020 on complexity classes, you can watch from min44 https://youtu.be/JbafQJx1CIA
I understand that other answers address the question from the Theory of Computation point of view not from Algorithms Design & Analysis; however I still believe, at least from my view, that it's different in meaning whether they're (NP) each independently polynomial reducible to an easy instance of an NP-Hard problem or to each other, only NPC problems have that property otherwise why stated separately???
& If factorization was in P there would have been no RSA at all & many other things. It's claimed polynomial only thru Quantum Computing.
ShAr
  • 138
    This statement is problematic. "Only NPC (NP-Complete) problems have such property they're reducible to each other in polynomial time". For example all non-trivial problems in $\mathsf{P}$ are reducible to each other in polynomial time (and it might be the case that $\mathsf{P} \neq \mathsf{NP}$). – Steven Sep 11 '21 at 14:36
  • It's most probable although not 100% sure, but not to be described "might", that P!=NP. Whether all problems in P are reducible to each other in polynomial time, I don't think so, they're each solvable in polynomial time, but that doesn't mean they can be transformed to each other; I think you mixed it up in your mind, but I'm not sure I will re-check – ShAr Sep 11 '21 at 15:12
    The fact that all (non-trivial) problem in P can be solved in polynomial time implies that they can be reduced to each other. The reduction from a problem $A$ to a problem $B$ is easy. Let $Y$ and $N$ be some arbitrarily chosen (and fixed) "yes" and "no" instances of $B$. Solve the instance of $A$ using any polynomial-time algorithm for $A$, if the instance of $A$ was a "yes" instance then return $Y$. Otherwise return $N$. – Steven Sep 11 '21 at 15:21
  • i think that diagram would be more valuable if it showed that NPC is subset of NP. – Effie Sep 11 '21 at 15:33
  • I think you mean the fact that any solution is verifiable in polynomial time, for sure this is true for problems in P too, but doesn't mean they're all transformable to each other's like those in NPC. – ShAr Sep 11 '21 at 15:35
  • And yes sorry, I added another picture the one with the intersections – ShAr Sep 11 '21 at 15:41
    No. I mean that the fact that the problems in $P$ are solvable in polynomial time means that they are all transformable (i.e., Karp-reducible) between one another (except for trivial problems). – Steven Sep 11 '21 at 16:13
  • Primality is in P, hence it is not NP-hard unless P = NP. Factorization, whose decision version is in $\mathrm{NP\cap coNP}$, is not NP-hard either, unless NP = coNP. And yes, Steven is perfectly right, any problems in P other than $\varnothing$ and $\Sigma^*$ are polynomially reducible to each other. – Emil Jeřábek Sep 11 '21 at 20:05
  • I think I'm more on the Algorithms Design & Analysis side of things as well, but I still don't think we should restrict poly-time reductions to "hard" problems. First of all, what if I don't know a problem $X$ is "hard"? Is my procedure that transforms $Y$ into $X$ a reduction? What should I call it? This seem unnecessarily difficult. Also, I think it is good for the algorithm designer to be open to reductions as a more general concept, as different types of reductions are central to the understanding and design of several FPT algorithms. – Discrete lizard Sep 15 '21 at 15:45
  • What do u mean if u don't know what complexity class X in?the whole idea if using reduction is to reduce a problem u don't know how to solve or what is the complexity nature to one u know. https://youtu.be/3DLH_jaQUfs , even those black boxes he talks about we know they're approximating NP-Hard. Also, what is FPT? I found a lot of possible words to the abbreviation – ShAr Sep 15 '21 at 20:39
