-1
Problem Statement: You are given a string s and two integers x and y. You can perform two types of operations any number of times. Remove substring "ab" and gain x points. For example, when removing "ab" from "cabxbae" it becomes "cxbae". Remove substring "ba" and gain y points. For example, when removing "ba" from "cabxbae" it becomes "cabxe". Return the maximum points you can gain after applying the above operations on s.
A greedy algorithm solves this problem in O(n). The greedy algorithm works by eliminating all pairs with a higher scoring value before removing pairs of a lower scoring value. Can anyone present a proof for the correctness of a greedy algorithm here. I have been trying, and I cannot convince myself.
B_math
  • 39
  • We require you to credit the original source of all copied material: https://cs.stackexchange.com/help/referencing. Copying without attribution constitutes plagiarism, and plagiarism is not ok. – D.W. Aug 13 '21 at 17:12
  • Please show us what you've tried, for trying to prove correctness. We have a guide on how to approach such proofs: https://cs.stackexchange.com/q/59964/755. – D.W. Aug 13 '21 at 17:13
(For the greedy algorithm described to be optimal, it is also necessary to assume that $x$ and $y$ are nonnegative.)
Without loss of generality, we can assume $y \ge x$.
Suppose to the contrary that the greedy algorithm is not optimal. Then there exist some string (possibly an intermediate state) containing a consecutive pair $\mathrm{ba}$ whose removal is suboptimal. Consider what happens to those letters in the optimal solution.
  • If neither is removed in the optimal solution, then also removing the pair gives a better solution – a contradiction.
  • If exactly one of those letters is removed in the optimal solution, then modifying the solution by first removing the $\mathrm{ba}$ pair, and omitting whatever removal applied to one of them later, gives another solution that is at least as good, contradicting the assumed suboptimality of removing the $\mathrm{ba}$ pair. (Because the other member of the pair was never removed in the optimal solution, this change works, in that it cannot break any later removals.)
  • If both of those letters are removed in the optimal solution, that means they are paired up with an $\mathrm{a}$ on the left and a $\mathrm{b}$ on the right. In this case, we can modify the solution by first removing the $\mathrm{ba}$ pair, and later pairing up and removing those other $\mathrm{a}$ and $\mathrm{b}$, which is again a contradiction.
m90
  • 221
