I'm trying the following question from my homework:
We're given a graph $G$ and parameters $k,\hat{P}, \hat{W}\in \mathbb{N}$. Additionally, each $v \in V(G)$ has a profit and weight: $p_v, w_v\in \mathbb{N}$.
Suppose you're given an $f(k) \cdot n^{O(1)}$-time algorithm $\mathcal{A}$ which finds whether there is a vertex cover $X\subseteq V$ with: $$|X| \leq k,\quad \sum_{v\in X} P(v)\geq \hat{P},\quad \sum_{v\in X} W(v)\leq \hat{W}$$ where $$P(v) = \sum_{s\in \{v\}\cup N(v)} p_s $$ $$W(v) = \sum_{s\in \{v\}\cup N(v)} w_s $$
The task is to find a polynomial-time algorithm that solves Knapsack (the decision version) using $\mathcal{A}$.
My attempts - given n items with profits and weights, $p_i, w_i$:
- Define a graph $G$ with 0 edges, where each vertex corresponds to an item. Now run $\mathcal{A}$ on $G$ with $k=n$. Clearly, the problem here is that the running time would be $f(n) \cdot n^{O(1)}$ - depends of $f$ whether the time is polynomial.
- In this attempt we'll try to run $\mathcal{A}$ multiple times. Define a graph $G$, where each vertex corresponds to an item. Now we'll consider every possible option for edges between $v_1$ to the other vertices and for each option we run $\mathcal{A}$ with these graphs and $k=1$. Now do the same for all possible edges between $v_2$ and all other vertices, and so on. This will take $n\cdot 2^{n-1}\cdot f(1)\cdot n^{O(1)} = 2^{n-1}\cdot f(1)\cdot n^{O(1)}$ - again, not polynomial.
Is it even possible to come up with a polynomial-time algorithm using $\mathcal{A}$?
Any idea (even if not an exact solution) would be very appreciated!
