As the question implies, can you mention any difference between Hidden Markov Model and Non-deterministic Finite-State Machine? Are they different or the same?
Asked
Active
Viewed 496 times
1https://cs.stackexchange.com/q/5008/755 – D.W. Feb 16 '21 at 21:47
Deterministic Finite State Machines have at most one trace for a given input. Nondeterministic Finite State Machines may have many traces for a given input. A Hidden Markov Model in some sense fits "in between" these extremes as the traces are probabilistic. With a Hidden Markov Model we do not have complete freedom to choose which trace to follow as we are governed by probabilities. A Hidden Markov Model is essentially a transducer-style Finite State Machine having outputs & transitions governed by a random process; the outputs generated at states are per a random variable model of what happens at that state, e.g., "if the weather is cloudy then 20% it will turn rainy / 80% it will turn sunny".
C8H10N4O2
- 746
- 5
- 11
Thank you for your answer. Now one question has arisen about the difference between Probabilistic Finite-State Machines and HMM!! Can you clarify this one? – Commander Feb 16 '21 at 17:58
