I'm trying to figure out an efficient way (without recursion) to convert a string (number representation) from one arbitrary base to another using custom alphabet. But I cannot think of a very fast efficient method (byte shift?) to do it:
def convert_base(target, base_from, base_to):
alphabet = '0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz'
base_to_alphabet_slice = alphabet[:base_to]
base_from_alphabet_slice = alphabet[:base_from]
result = ''
for char in target:
result += ...
return result
Expected results:
print(convert_base('E', 16, 2))
Output: '1110'
print(convert_base('1110', 2, 16))
Output: 'E'
print(convert_base('E', 16, 10))
Output: '14'
Can someone suggest a good method for this?
0123456789ABCDEF
to convert numbers from base10 to base16 and back. I extended the alphabet just so I can convert larger bases. – AlekseyHoffman Nov 18 '20 at 23:35
