It can be shown that Turing machines, μ-recursive functions and reasonable programming languages can compute/decide the same problems. I wonder why we then still proof the halting problem with Turing machines.
Isn't it much easier to argue that the function halts below cannot exist in e.g. python since then I would be able to write the following program which is a contradiction.
def halts(source):
if name == "main": this_file = open(file) if halts(this_file.read()): while True: pass else: return 1
Why is this proof not as good as the TM diagonal argument?
Edit: I read https://cs.stackexchange.com/a/94235/119946
OK, fine. This proves that the halting problem can't be solved for code written in any programming language that has a get_source_code_of_current_function() API. However, my favorite programming language doesn't have such an API. So, this proof doesn't prove anything about my favorite programming language -- perhaps the halting problem is solvable for my language, who knows? Similarly, Turing machines don't have such an API, so this doesn't prove that the halting problem for Turing machines is undecidable.
I mean by that argument I can say the TM proofs only shows that the halting problem cannot be decided by Turing machines, but does not show anything about python. Isn't the crucial part, that (as I wrote) TM and modern programming languages can compute/decide the same problems? If one can decide the halting problem, then all other can do so as well and vice versa.
  • A good thing about Turing machines is that they are simple. In your code, you need to formally define what means def, return, open, read, __name__, ==, etc. etc. Sounds like a lot of pain. 2) Python is Turing-complete, i.e. you can simulate TM with python. The halting problem says that you can't say whether the TM halts $\implies$ whether the simulation halts $\implies$ whether your python program halts.
  • –  Oct 23 '20 at 16:30
  • I can be shown that TMs can simulate register machines e.g. modern computers. Hence, you can run python on them. The keywords you mentioned are already defined in the python spec. – Manuel Schmidt Oct 23 '20 at 16:36
  • I don't understand the point of the first part of your comment. You've written I can say the TM proofs only shows that the halting problem cannot be decided by Turing machines, but does not show anything about python. I explained it does show the same thing about Python. The keywords you mentioned are already defined in the python spec sure, they probably are. And all these definitions must be taken into account when you try to proof stuff about your code. You need to formally define the semantics, and instead of 1 page for TM it'll be hundreds? of pages of specification. –  Oct 23 '20 at 16:41
  • I don't say you can't show that halting problem is undecidable for Python. I'm saying that 1) It's simpler to show that for TM. 2) It implies result for Python. –  Oct 23 '20 at 16:43
  • OK, then I agree with you on 2). You missed the I mean by that argument, ... part while quoting me. I disagreed with the cited answer, and with 1) as my "proof" above is easier than the diagonal argument. The spec is already written and it follows whether python halts $\implies$ wether the TM simulation of it halts $\implies$ whether the TM halts. – Manuel Schmidt Oct 23 '20 at 16:50
