As I understand emulation a rule of the thumb says that a computer must be around a order of magnitude more powerful to emulate another system without resorting to tricks. This is because for every clock cycle of the system to be emulated, the host machine must process that cycle in the correct time and also process its own cycles.
A Xbox 360 uses a 3.2GHz PowerPC Tri-Core Xenon
processor, would this mean that emulating the console on a 3GHz PC CPU would be impossible, even if the host CPU was more powerful but not faster for clock cycles?
To give a more straightforward example. A i7 that runs at the same clock speed as a Pentium 4 will not be able to emulate the Pentium 4, even though the i7 is many times more powerful.
In addition, does this mean that to emulate the Xbox 360, The host computer must run at a speed of between 9GHz and 3.2GHz to be able to truly emulate a Xbox 360?
If this is the case, surely there must be a way around this limitation? If we had a host computer with 10x3GHz CPU's could this system use parallelzation to somehow emulate a 3 core 3.2GHz system.
Also the emulate should run at the speed that the user expected of the emulated system, I know if you slowed down the Xbox 360 on the emulator by a few times then it would be easier, I want to know if we can emulate a system at the speed it was meant to run.
If this is not possible does that mean that for emulation, clock speed is king? And there is no way around this? Even if your host machine had a thousand CPU's running at 2GHz it could never ever emulate a Xbox 360 at its native speed?
By the way I am sure this is in the domain of computer science. I am not sure exactly what it comes under but the simulation of a system within a system and inherent limitations is certainly applicable to computer science.
What about this: could a 4 core 3GHz i7 CPU emulate in proper time a 3.8GHz single core Pentium 4?
