I am trying to understand the example given here of an EXP-SPACE time decision problem.
They write :
An example of an EXPSPACE-complete problem is the problem of recognizing whether two regular expressions represent different languages, where the expressions are limited to four operators: union, concatenation, the Kleene star (zero or more copies of an expression), and squaring (two copies of an expression)
Here is what I understand. Supposing I have some alphabet $\Sigma = \{a,b,c...,z\}$, then a regular expression is a pattern in order to specify the set of strings that belong to some language.
So for instance if I have two regular expressions, say
$aa+a^{*}+bb^2$ then any string that satisfies this expression is in $L_1$ (language 1),
$abc$ then any string that satisfies this expression is in $L_2$
Why does determining if these languages are the same in the worst case take exponential space. Further what is the size of the input ? I imagine it could be the sum of lengths of the two reg-expressions, but I am not sure.
Edit: If the Kleene star criterion is dropped, then I could see that we could simply create a set with all possible strings (the power set), and then compare the two sets, not sure about the input size however.
IntegrateThis
  • 239
  • Why is this problem EXPSPACE-hard? This requires a proof. Perhaps Wikipedia has a link to one. – Yuval Filmus Jan 31 '20 at 04:18
  • @YuvalFilmus right, and here it is: http://people.csail.mit.edu/meyer/rsq.pdf, I will read this and try and give a sketch in the next few days or so. – IntegrateThis Jan 31 '20 at 05:23
