Can I solve T(n) = 2T(n − 1) + 1 using the master theorem method? I don't think it cannot be solved with the master theorem because b=1. Please let me know, if my guess is wrong.
Can you solve the problem at all? Write down T(1), T(2) up to T(10). It is irrelevant how you solve a problem outside homework questions, which we don’t answer. – gnasher729 Oct 10 '19 at 15:41
2Possible duplicate of Solving or approximating recurrence relations for sequences of numbers – ryan Oct 10 '19 at 18:40
Here are several ways of solving this recurrence. Throughout, I will assume that $T(0) = 0$.
Method 1: Guessing
Here are some values of $T(n)$: $$ \begin{array}{c|cccccc} n & 0 & 1 & 2 & 3 & 4 & 5 \\\hline T(n) & 0 & 1 & 3 & 7 & 15 & 31 \end{array} $$ If you're familiar with powers of 2, you will recognize that $T(n) = 2^n-1$. If not, you can look it up on the Online Encyclopedia of Integer Sequences, where you will find it as A000225, under the name Mersenne numbers.
Method 2: Homogenization
We look for a related recurrence without the "$+1$". The first think one could try is replacing $T(n)$ with $S(n) = T(n) + C$, which satisfies the recurrence $$ S(n) = T(n) + C = 2T(n-1) + C + 1 = 2S(n-1) - C + 1. $$ We see that if $C = 1$ then $S(n) = 2S(n-1)$, and so $S(n) = 2^n S(0) = 2^n$. We conclude that $T(n) = 2^n - 1$.
Method 3: Reduction
The recurrence makes it clear that the first order asymptotics of $T(n)$ should be related to $2^n$, and so suggests considering $R(n) = T(n)/2^n$, which satisfies the recurrence $$ R(n) = \frac{T(n)}{2^n} = \frac{T(n-1)}{2^{n-1}} + \frac{1}{2^n} = R(n-1) + \frac{1}{2^n}. $$ This shows that $$ R(n) = R(0) + \sum_{m=1}^n \frac{1}{2^m} = 1 - \frac{1}{2^n}, $$ and so $T(n) = 2^n - 1$.
If we are only interested in the asymptotics, we could notice that since the series $\sum_{n=1}^\infty \frac{1}{2^n}$ converges, we clearly have $R(n) = \Theta(1)$, and so $T(n) = \Theta(2^n)$.
Method 4: Generating series
We could also solve the recurrence automatically using generating series. Let $$ P(x) = \sum_{n=0}^\infty T(n) x^n. $$ Then $$ P(x) = T(0) + \sum_{n=1}^\infty T(n) x^n = 2\sum_{n=1}^\infty T(n-1) x^n + \sum_{n=1}^\infty x^n = 2xP(x) + \frac{x}{1-x}. $$ We conclude that $$ P(x) = \frac{x}{(1-x)(1-2x)} = \frac{1}{1-2x} - \frac{1}{1-x} = \sum_{n=0}^\infty (2^n - 1) x^n. $$ Therefore $T(n) = 2^n - 1$.
Method 5: Combinatorial interpretation
This method is more creative. We find some combinatorial object which we already know how to count, and we show that it satisfies the same recurrence. In this case, we could choose all non-empty subsets of $\{1,\ldots,n\}$. Each such subset is either obtained from a non-empty subset of $\{1,\ldots,n-1\}$ by either adding or not adding $n$, and additionally the subset $\{n\}$, which does not arise in this way. The base cases also match, and so $T(n) = 2^n - 1$.
- 276,994
- 27
- 311
- 503
You can only solve equations using the Master Theorem if they are of form $T(n) = aT(n/b) + f(n)$, where $a \ge 1$ and $b > 1$.
Here you can't express your recurrence in above form. And your guess of taking $b = 1$ is completely wrong. The reason for not using the Master Theorem is that you can't express your recurrence in form $T(n) = aT(n/b) + f(n)$ where $a \ge 1$ and $b > 1$. You would able to use the Master Theorem if the equation were $T(n) = 2T(n/2) + 1$, in which case $a = 2$ and $b = 2$.
In order to solve your recurrence equation $T(n) = 2T(n-1) + 1$, you will have to use a recursion tree, and then verify the solution using induction.
- 276,994
- 27
- 311
- 503
- 11
- 2
the equation he gives is in form of master method, where a = 2 and b = 1, and the reason why master is can't be applied is because log(2) of base 1 – Mohamed Fathallah Nov 22 '23 at 20:14
A short and direct answer to this question is "NO"
because master can't be applied because b = 1
and master method needs a>=1 and b>1
not equal
- 101
- 1
