I am currently studying mapping reduction in computational theory and finding it hard to grasp the concept fully.
For reference, consider the following given WHILE-Prog sets:
A = { (p.d) | p doesn't halt on input d } = Complementary HALT set. B = { p | p halts on exactly one input (the input is unknown) }
Is A < B. meaning, is there a mapping reduction from A to B?
Can someone suggest a hint?
knowing that A belongs to coRE did not help much. B doesn't seem to belong to either RE nor coRE.
dkaeae
  • 4,997
Tom.A
  • 113
  • Try attacking the problem directly, i.e., constructing an instance of $B$ from an instance of $A$. – John L. May 22 '19 at 23:51
  • @Apass.Jack, Thanks for the comment. – Tom.A May 23 '19 at 05:37
  • @Apass.Jack , That's what I was trying to do, however, it seems to be very confusing. The mapping should behave as follows: 1. A -> B : it means that [p]d did not halt, so I should return a program q such that q halts on one particular input only. this is quite easy by returning a program that loopsforever on inputs different from nil. 2. not A -> not B: this is where I am mostly confused, as if [p]d halts, I should return q such that either one of the following occurs: 1. [q] doesn't halt on any input. 2. [q] halts on at least two inputs. – Tom.A May 23 '19 at 05:45
  • Welcome to [cs.SE]! Note that you can use LaTeX here to typeset mathematics in a more readable way. See here for a short introduction. – dkaeae May 23 '19 at 07:24
  • $A = { (p, d) \mid p \text{ doesn't halt on input }d }$. What is $p$? Is it a Turing machine? Or a program? – John L. May 23 '19 at 16:47
  • p is a program. – Tom.A May 23 '19 at 16:48
One basic idea is to observe that $B$ looks harder than $A$ since
  • we need to run a given Turing machine on one given input in order to find whether the pair is in $A$ but
  • we may need to run a given Turing machine on infinity many inputs in order to find whether it is in $B$.
That observation should motivate us to find a reduction from $A$ to $B$.
Suppose $(p,d)\in A$. Construct a machine that behaves as the following.
Upon an input string $s$, it checks whether $s$ is $d\sigma$, where $\sigma$ stand for a fixed letter in the alphabet.
  • If yes, it halts.
  • If no, it checks whether $s$ is $d$.
    • If no, it loops forever.
    • If yes, it simulate $p$ on $d$.
It should be routine to verify the construction above is indeed a reduction from $A$ to $B$.
John L.
  • 38,985
  • 33
  • 90
  • Thank you for your answer. The course I am taking does not rely on a Turing machine even though it seems like the common way. As far as what I have learned thus far, the reduction should map instances from A TO B and from Complementary A to Complementary B. – Tom.A May 23 '19 at 15:41
  • Can you explain what do you mean by comparing s to dσ ? never dealt with such inputs, just tree based inputs consisting of nil's e.g (nil.nil), ((nil.nil).nil), etc. – Tom.A May 23 '19 at 15:44
  • Replace "Turing machine" and "machine" by program everywhere in the answer. – John L. May 23 '19 at 16:58
  • $s$ is a string. $d\sigma$ means the string that is the string $d$ followed by the letter $\sigma$. "Checking whether $s$ is $d\sigma$" just means whether the string $s$ is equal to the string $d\sigma$, i.e., whether the first letter of $s$ and that of $d$ is the same, whether the second letter of $s$ and that of $d$ is the same, ..., whether the second last letter of $s$ and the last letter of $d$ is the same, and whether the last letter of $s$ is $\sigma$. (I assume, WLOG, every input is a string over some alphabet.) – John L. May 23 '19 at 17:01
  • I got it! :) Thank you so much. A few things I would like to ask: 1. What guided you through the process? I am finding it hard to grasp how much it is possible to write a program that halts which relies on a program that doesn't. 2. Are there any relevant papers to review online for reference? Yet again, Thanks a lot! – Tom.A May 23 '19 at 17:14
  • Those two questions are harder to answer. 1) Pattern recognition, practice, experience and luck. 2) You could search for "examples Turing machine reduction". This question and answer might be helpful. – John L. May 23 '19 at 18:33
