I know that there are cases when RSA will not work like when the number to feed into the system is greater than the modulus. I was wondering if there were any other cases when RSA won't work
I looked all over and tried rephrasing the question in google many times
Edit: I am looking for what cases exist with a valid n, e and d used properly will not encrypt and decrypt correctly eg: message <= n
Kai Arakawa
  • 145
It should be proven in any presentation of RSA that, with a correct public modulus $N$, public exponent $e$ and private exponent $d$, all integers $m \in \{0,1,\dots,N-1\}$ satisfy $$\left(m^e\bmod N\right)^d\bmod N = m.$$ So it is only possible for a number to "not encrypt or decrypt correctly" when it is not in $\{0,1,\dots,N-1\}$. Moreover, this necessary condition is obviously also sufficient, because the result of a $\bmod N$ operation will be in this set, so if $m$ is outside it, it can't possibly equal the result of the above computation.
fkraiem
  • 8,112
  • 27
  • 38
  • Search the forum for 'unconcealed messages'. There are a minimum of 9 messages which result as the original message (quine). – Carl Knox Nov 05 '17 at 18:53
