Let $G$ be a cyclic multiplicative group of order $n$. Let $g$ be a (public) generator of $G$. The Diffie-Hellman (DH) problem asks: Given $g^x, g^y\in G$ for $x, y\in \mathbb{Z}^*_n$, to compute $g^{xy}\in G$.
Let $O$ be an oracle that works as follows: it takes as input $g^x\in G$ for any $x \in \mathbb{Z}^*_n$, it outputs $g^{1/x}\in G$. In other words, $O(g^x)=g^{1/x}$. I call this the "Discrete log inversion" oracle for lack of a better name.
Can we use $O$ to solve the DH problem. I remember reading about this somewhere but can't locate the reference.
Note: $1/x$ is defined as the inverse of $x \in\mathbb{Z}^*_n$.
EDIT: To visualize such a group, let $n=15$ and consider the subgroup of $\mathbb{Z}_{31}^*$ generated by 7, which is $\{1, 7, 18, 2, 14, 5, 4, 28, 10, 8, 25, 20, 16, 19, 9\}$, containing exactly 15 elements. In this case $G=\{7^i \bmod{31}|i \in \mathbb{Z}_{15}\}$
Jus12
  • 1,659
  • you want $(O(g^x))^x\equiv g\equiv (g^{1/x})^x \pmod n$ to hold. Right? – SEJPM Jun 12 '15 at 17:45
  • if so, I think "$1/x$ is defined as the inverse of $x\in\mathbb{Z}^*_{\phi(n)}$", with $\phi(n)$ denoting the group order. – SEJPM Jun 12 '15 at 18:02
  • That's what I meant, if you want that $g^{(1/x)x}\equiv g \pmod n$, you need to choose $d:=1/x$ such that $ed\equiv 1 \pmod{\phi(n)}$ (logic stolen from RSA) – SEJPM Jun 12 '15 at 18:28
  • @SOJPM; $(O(g^x))^x = g\in G$ (not $\bmod{n}$). Edited question to make this clear. – Jus12 Jun 12 '15 at 18:38
The answer is yes; see Chapter 21 of Galbraith's book. Suppose we have your Fixed-Inverse-DH oracle $O(\cdot)$, and given $g^a$ and $g^b$ we want to find $g^{ab}$. We do this in two steps. First, we use $O$ to compute $g^{a^2}$ from $g^{a}$—this is a related problem called the Square-DH problem. Then we use the quarter-squares identity to compute $g^{ab}$.
To compute $g^{a^2}$ from $g^a$ using $O$, we perform:
$$ \begin{align} x &= O(g g^a) = g^{1/(1+a) \bmod n} \\ y &= O(g / g^a) = g^{1/(1-a) \bmod n} \\ z &= O((xy)^{1/2 \bmod n}) = g^{1 - a^2} \\ w &= g / z = g^{a^2}. \end{align} $$
Let's call the above procedure $S(\cdot)$. Now, we use the quarter-squares identity
$$ (x + y)^2 - (x - y)^2 = 4xy, $$
to compute $S(g^{a}g^{b}) / S(g^{a}/g^{b}) = S(g^{a+b}) / S(g^{a - b}) = g^{(a+b)^2 - (a-b)^2} = g^{4ab}$. Exponentiate to ${1/4 \bmod n}$ and obtain $g^{ab}$.
Samuel Neves
  • 12,460
  • 43
  • 52
  • Thanks for the ref. Some related questions: Suppose $n$ is composite and hard to factor. Which of the problems in Ch 21 are reducible? (1) Can Inverse-DH be reduced to Fixed-Inverse-DH? (2) Can Fixed-Inverse-DH be reduced to Fixed-DH? – Jus12 Jun 13 '15 at 06:00
