I have several coils of yellow agricultural PVC hose.
My intention is to paint them, and to use them to represent thick high voltage cable for a prop. They will be completely static in coils, and will not be required to flex or bend. In fact this will be discouraged by fixing them in place as much as is practical.
They are a salvaged material, and while not ideal for my purposes they are free and available.
I intend to clean them with a degreasing agent, sand the surface down lightly, clean them a second time to remove dust created by sanding, and then to paint them.
Are there any specific techniques, products, or product families that would help me to achieve a high quality result, or which should be avoided?
For example, specific types of paint that would adhere well to a pvc surface, or which would adhere poorly
