15
Related to What is the difference between sea salt and regular table salt?
What can I prepare that will work really well for a side-by-side comparison to demonstrate the difference between sea salt and regular table salt? Obviously, tasting the salts directly might work, but I'm looking for something that highlights the difference and is tasty at the same time.
Edit:
I'm looking for things that highlight the differences in the flavors of the salts or that the salts affect the flavor significantly due to the trace minerals. Why are the things you suggest ideal for this? I'm not looking for a list of foods you can add salt to - that list is endless.
Why should I use sea salt?
Here's a hypothetical example answer:
Adding sea salt to X makes it taste salty in the same way as table salt does. However if you use Y, the A will be B and the C will be D. You will notice a distinct difference.
Dennis Williamson
  • 1,092
  • 22
  • Too open-ended and is really a recipe question...vote to close – AttilaNYC Aug 08 '10 at 14:25
    @AttilaNYC: Please explain. And why are some of your questions not "open-ended" and "really a recipe question"? – Dennis Williamson Aug 08 '10 at 16:24
  • Pretty much anything salty is going to demonstrate the difference. So IMO, this essentially does equate to a request for salty recipes, which without any further criteria is wide open to anyone. At the very least, it's a "list of X" question and should be community wiki. – Aaronut Aug 08 '10 at 18:03
    This is a great experimental question, with a focus on learning about and showcasing the different qualities of ingredients. It's brilliant. It is what makes great chefs and enlightened eaters. It's not a recipe question because it's just asking for serving ideas. – Ocaasi Aug 08 '10 at 21:20
    I don't see this as a recipe question at all. the OP wants to know how to best judge the difference in flavour of various salts. this is a great question I believe, and one where the answer is almost certainly not a dish. – Sam Holder Aug 09 '10 at 15:11
  • @cinque @Sam Holder. I support keeping plenty of questions open provided they are improved, but this one really should be. Hope you'll add your reopen votes as your comments suggested. – Ocaasi Aug 11 '10 at 12:54
  • meta discussion started: http://meta.cooking.stackexchange.com/questions/566/should-this-question-have-been-closed – Sam Holder Aug 11 '10 at 13:24
6 Answers6
14
Much agreed with Krister that simple is best. Also, to really emphasize the difference, I'd aim for larger flakes of both the 'regular' salt and the sea-salt. Here are some serving ideas.
  1. Just the salt. Side by side, on a dark plate with some small divider. A pinch of each. That's it.
  2. Broth. A very simple vegetable broth, made with a little butter (unsalted of course) and fresh tomato, and perhaps a sprig of fresh thyme or rosemary, warmed to about 160 degrees, and strained through cheesecloth. I'd add about 2/3 the salt during cooking and a few 'fresh' flakes at service.
  3. Fish. Preferably raw. A piece of sushi-grade salmon would be delicious. Add a few flakes of salt.
  4. Meat. Take one very good, very fatty, very juicy piece of meat. Sear it on all sides to about medium rare. Salt.
  5. Chocolate. Salt is a wonderful accompaniment to dark chocolate. And dark chocolate with caramel. Make or purchase such a confection, and serve two side by side with a few flakes of each salt on top.
  6. Fruit. I recommend a piece of watermelon. Possibly grilled. With salt.
  7. Tea. Find a good recipe for salt tea, popular in parts of Asia. Serve in two small Japanese style tea cups.
You have lots of options. Small portions will be key. Not overcooking anything will be key. Interesting options whether or not to tell your guests ahead of a dish which preparation is which, or let them to identify the difference with their palettes. Perhaps a combination, letting them try to guess at first, then with instruction, and finishing with guessing again. I'd add in some history, possibly from the highly recommended book Salt. Or just Wikipedia. Tell them all of the functions salt serves in our bodies, but especially in the transmissions of flavor on the tongue. Great idea...!
Ocaasi
  • 5,761
  • 27
  • 43
I think something very basic like a slice of ripe tomato or some avacado will help showcase the flavour difference between salts. Tomato would be my choice as it responds well to salting, really bringing out the tomato flavour. You can tell the difference between the 'harsh' salting of table salt vs the mellow flavour enhancement of something like Maldon, the king of salt.
Sam Holder
  • 11,290
  • 69
  • 114
Anything elaborate makes it hard to do comparisons. You could make your own butter with different types of salt and serve with some good bread. Another option could be drinks with a salted glass rim like margaritas.
Krister Olsson
  • 296
Focaccia topped with salt.
grm
  • 537
Make real bavarian Brezes. I know that pretzel is used in English to mean basically any baked good which has the distinct shape, but in Bavaria, it is always made from soft yeast dough, pre-boiled in lye, covered with big salt flakes and baked. At home, it is acceptable to cook them in a strong baking soda solution instead of lye.
When you eat a bavarian Breze, you can distinctly taste the salt used on it. The dough softens/dilutes the salt concentration, so you don't have the sensory overload likely to be caused by eating a pinch of pure salt (which will keep you from noticing the fine notes of difference between the two salts), but it does not add to much of an own taste, so it doesn't mask the difference. Thus it should be very well suited for comparing the two salt types.
A recipe in English shouldn't be too hard to find. If you want an original German recipe, you can try this one. The translation rendered by Chromium is funny at some places, but generally well understandable, you shouldn't have trouble following it.
It is probably a good idea to use the different salt on separately baked batches, as the flakes get everywhere while baking and would mix if used on the same baking sheet.
When you have finished the taste test, you can eat the rest of the batch with cooked wieners and mustard (as per tradition), or just use it instead of bread.
rumtscho
  • 138,730
  • 45
  • 311
  • 565
  • "walk in the warmth" indeed! It's Google, rather than Chromium that's doing the translating, by the way. Chrome (and I presume Chromium) simply has a feature that offers to initiate the translation. In American English, "wieners" means "hot dog meat" (aka "frankfurters" - or at least what we think of them as) and "vienna sausages" (as translated in the recipe) means a small canned product that's a little bit similar to American hot dogs. I know those terms have different meanings in Germany. – Dennis Williamson Feb 25 '11 at 23:37
Pure iodized salt is almost too salty whereas sea salt and other salts made with minerals are tempers it just a bit. Put a pinch a salad with a little olive oil (no vinegar). Sea salt enhances and complements the flavor trio but traditional table salt is just too strong and overwhelms. I enjoy the flavored salts---like smoked or Merlot salt.
Incidentally, salt on the salad is an old Roman tradition. Roman soldiers used to receive bags of salt as part of their payment. Hence the origin of the term "salary." Kinda cool!
Spice Sherpa
  • 390
