Items placed in my freezer take on an awful flavor that tastes a lot like freezer burn, even ice cubes. If I put items in the freezer over-night and it isn't tightly covered, this problem occurs.
With the ice cubes I can rinse them off to eliminate the bad flavor, but I'd prefer to find the root cause and fix it.
Any ideas/suggestions are quite welcome.
Brian Vandenberg
  • 163
Freezer burn occurs when water molecules in food gather in a colder location in your freezer—whether that be the sides of your freezer or even other foods.
Tips to prevent freezer burn:
  • Don't put hot food directly into your freezer, let it cool first
  • Put your food in air-tight containers
  • The longer food is in the freezer the greater your chance of freezer burn
I'm going to go out on a limb though and guess that—at least with your ice cubes may just be acquiring a "freezer smell" from the other foods in your freezer. If I don't use the cubes in my freezer fast enough they end up tasting really unpleasant. Give your freezer a good cleaning and cover your ice cubes with saran wrap and this should help stop the funny smells/tastes.
Vecta
  • 2,694
  • 22
  • 24
    The baking soda "trick" is little more than a clever marketing ploy and popular myth. Although it might absorb a very small amount of odour, it's really very ineffective. – Aaronut Aug 19 '11 at 15:43
    Hmm, good to know. Seems as if using activated charcoal to control odors is a more accepted method now. http://www.newton.dep.anl.gov/askasci/chem00/chem00388.htm – Vecta Aug 19 '11 at 15:50
  • Excellent point @Vecta, I was wondering what 'freezer smell taste' was. – Katey HW Aug 19 '11 at 17:41
  • I'll try the activated charcoal. Thank you to everyone to contributed. – Brian Vandenberg Aug 19 '11 at 17:42
Here are some tips for preventing freezer burn:
http://www.wikihow.com/Prevent-Freezer-Burn
The most important thing is to keep the temperature of your freezer constant and as low as possible (below 0 degrees Fahrenheit).
clueless
  • 3,030
  • 26
  • 51
  • 54
-3
I found out that the "freezer" taste comes from the free-on(?) used in frost-free freezer's.
julie
    Freon (a DuPont brand name, commonly for dichlorodifluoromethane aka R-12) is (a) no longer used, under the Montreal Protocol; (b) is contained inside the refrigeration system, and isn't released into the freezer compartment (and, if it were due to a leak, the freezer would cease to function); (c) the smell of freon is entirely inconsistent with freezer taste; (d) its very much a gas, even at freezer temperatures; (e) when it was used, it was used in both self-defrosting and non-self-defrosting freezers (and air conditioners, etc.) – derobert May 20 '12 at 05:38
