14
When a capture can be made by two rooks, or two knights, etc., how does the notation clarify which piece makes the capture?
For example, if two pawns, one at e4 and one at c4, capture a pawn at d3, the notation will say exd3 or cxd3, sure. But if two knights capture the same piece, how is that notated? Or for two rooks, or queens? In the case of the knight, it would only say Nxd3, but that doesn't clarify which knight took the piece.
psmears
  • 123
    In case of doubt, one can always fall back to the "long" notation, e.g. Nf2xd3 or Rd1xd3. But I guess that is not exactly what you are looking for. – Annatar Mar 20 '18 at 10:01
  • By the way, you should replace the word "attack" with "capture" in your first sentence. "Attack" in chess generally only means the threat to take a piece, not the actual act of doing so. – Annatar Mar 20 '18 at 10:02
Your two knights are on d2 and f2.
Ndxe4, Nfxe4,
Your two knights are on f2 and f6.
N2xe4, N6xe4
Your three knights are on d2, f2 and f6 (you promoted a pawn)
Ndxe4, Nf2xe4, N6xe4
David Richerby
  • 2,807
  • 32
SmallChess
  • 22,476
  • 45
  • 82
Assume you have Knights on e5 and c5. If Nc5 captured on d3, you would write:
1...Ncxd3
If Ne5 captured on d3:
1...Nexd3
The key is using the column letter to distinguish pieces.
If the pieces are on the same column, such as Knights on e4 and e6, then you would distinguish via their row numbers. Example:
If Ne4 captured on g5, you would write:
  1. N4xg5
If Ne6 captured on g5, you would write:
  1. N6xg5
If you have the choice of distinguishing between column letter and row number, choose column letter. This isn't required by any means, but it tends to be the convention. Example -- Rooks on e6 and g4.
If Re6 captured on g6, you should write:
  1. Rexg6 (not R6xg6).
Inertial Ignorance
  • 19,818
  • 23
  • 70
    If you've promoted and have three of a particular piece, you might not be able to use either row or column to disambiguate. For example, with knights on d2, f2 and f6, you'd have to write Nf2xe4 if capturing with that piece. – David Richerby Mar 20 '18 at 20:11
  • @David Richerby Yeah that's true, never thought of a case like that before. – Inertial Ignorance Mar 21 '18 at 01:19
