How is solubility different from dissolution? And how are they both different from solvation?
tschoppi
  • 10,827
  • 43
  • 89
Uzair
  • 555
5 Answers5
Solvation [...] is the process of attraction and association of molecules of a solvent with molecules or ions of a solute. As ions dissolve in a solvent they spread out and become surrounded by solvent molecules. [...]
Dissolution is a kinetic process, and is quantified by its rate. Solubility quantifies the dynamic equilibrium state achieved when the rate of dissolution equals the rate of precipitation.
Quote from Wikipedia.
tschoppi
  • 10,827
  • 43
  • 89
Solubility is a chemical property referring to the ability of a given substance, the solute, to dissolve in a solvent. Dissolution, or solvation, is the process by which a solute interacts with and becomes dissolved in a solvent due to an increase in stability.
scollado
  • 43
Solubility is maximum amount of solute that will dissolve in a given solvent at a given temperature to form saturated solution. Dissociation is a more kinetic process which depend on lattice and hydration energy.
Martin - マーチン
  • 44,013
  • 159
  • 319
• Dissolution is the process where a solute dissolves in a solvent to form a solution, whereas solubility is the outcome of dissolution.
• Solubility is a thermodynamic entity whereas dissolution is kinetic.
• Solubility is measured in mol/kg and dissolution is measured in mol/s
solubility:
  • the capacity of solute to be dissolved in a given amount of solvent (how many moles of solute are dissolved)
  • solutes solubility is always questioned
  • it is a thermodynamic process
  • its unit is mol/kg
dissolution:
  • rate of solute dissolving in a solution (how fast the solute dissolves)
  • solute is always soluble
  • it is a kinetic process
  • its unit is mol/sec
pentavalentcarbon
  • 7,488
  • 47
  • 78
