Both nitrogen and phosphorus have 5 valence electrons, but nitrogen has valency of 3 while phosphorus has valency of 3 or 5. Why is this so?
Maybe phosphorus can gain 3 electrons or remove 5 electrons.But is it possible to remove 5 electrons? Or is it that phosphorus valence shell is farther away than nitrogen, so it is easier for phosphorus to also remove 5 electrons but nitrogen cannot.
I have searched but i need a concrete answer.
- 11
- 1
- 1
https://chemistry.stackexchange.com/questions/62218/why-can-phosphorus-have-5-bonds-while-nitrogen-cannot – Mithoron Jun 13 '17 at 15:56
4Possible duplicate of Can an atom have more than 8 valence electrons? If not, why is 8 the limit? – Mithoron Jun 13 '17 at 16:27
2The question is utterly different from the proposed duplicate, @Mithoron. – Jan Jun 13 '17 at 16:46
@Jan But it's standard dupe for hypervalent stuff. In this case lots of reasons would do. For example claim about valencies isn't true, they are identical for both elements. – Mithoron Jun 13 '17 at 17:44
At your current stage, it's probably easiest to consider the octet rule which applies to nitrogen and the expanded octet rule which applies to phosphorus.
If nitrogen and phosphorus made five bonds, they would have 10 electrons total. This is inconsistent with the octet rule but valid under expanded octet.
In reality, the situation is governed by the fact that you need more orbitals to accommodate the extra electrons for the two extra bonds. Unfortunately, no orbitals of comparable energy to the $2s$ and $2p$ are available, so the stabilization of the electrons in the putative molecular orbitals would be poor in nitrogen. With phosphorus, you might more readily access the $4s$ and $3d$ orbitals which are closer in energy to the $3s$ and $3p$ orbitals.
- 17,392
- 1
- 38
- 70
