What is the pH of $10^{-8}~\mathrm{M}$ $\ce{HCl}$ solution in water?
My attempt:
pH = $-\log(10)^{-8}$ = 8
But this is wrong because it should be acidic. Where have I gone wrong?
My attempt:
It is known that the equilibrium constant for the following reaction is $10^{-14}$.
$$\ce{2H2O(l) <=> H3O+(aq) + OH-(aq)}$$
That means,
$$\frac {[\ce{H3O+(aq)}][\ce{OH-(aq)}]} {[\ce{H2O(l)}][\ce{H2O(l)}]} = 10^{-14}$$
where the concentration of water $[\ce{H2O(l)}]$ is assumed to be $1$.
Initially, we have $[\ce{H3O+(aq)}] = 10^{-8}$.
Then, assuming that $x$ moles of $\ce{H3O+(aq)}$ is generated. An equal amount of $\ce{OH-(aq)}$ must also be generated:
$$(10^{-8}+x)(x) = 10^{-14}$$
Solving for $x$ gives $x = 9.51 \times 10^{-8}$.
So, the total concentration of $\ce{H3O+(aq)}$ is $1.051\times10^{-7}$.
Therefore, the pH is $6.978$.
Let the initial molarity of the hydronium ion be $a$.
Solving $(a+x)(x) = 10^{-14}$, if $a$ is well above $10^{-5}$, gives $x \approx 0$.
The approximation that the pH is equal to $-\log{{\left([\ce{HCl(aq)}]\right)}}$ is only accurate for normal concentrations.
This answer uses a simplification! It assumes that the concentration of $\ce{H3O+}$ as contributed by $K_\mathrm{w}$ is constant at $10^{-7}~\mathrm{M}$. This is incorrect. In reality, an additional equation must be introduced and the resulting formula is cubic rather than quadratic. Unfortunately, solving a cubic equation is very non-trivial and I am not able to do it. One possible cubic equation with which the final value should be calculateable is the following:
$$x^3 + K_\mathrm{a}x^2 - (K_\mathrm{a}c_0)x - K_\mathrm{a}K_\mathrm{w} = 0\\ x = [\ce{H3O+}]$$
Due to the approximation, this answer is off the actual value. The other answer uses a different simplification which arrives at a result closer to the actual value. I’m leaving this post here for posteriority, because it still serves to exemplify how complicated the calculation must be at least and how easily a pitfall is encountered.
You used the simplified equation $(1)$ wherein acid is a strong, monoprotic acid. It encompasses a few shortcuts that are only valid for reasonably concentrated strong acids. Using it for an acid this dilute will break a lot of the assumptions used. To clarify, I will use the long method.
$$\mathrm{pH} = -\lg c_0(\text{acid})\tag{1}$$
Upon dissolution of any acid (using hydrogen chloride as an example, but any will work) equilibrium $(2)$ will be found.
$$\ce{HCl + H2O <=> H3O+ + Cl-}\tag{2}$$
This equilibrium can be adequately described by the acidity constant $K_\mathrm{a}$ which is defined as shown in equation $(3)$ (note that where concentrations are implied, activities are actually used. The solvent does not show up because its activity is $1$).
$$K_\mathrm{a} = \frac{[\ce{H3O+}][\ce{Cl-}]}{[\ce{HCl}]}\tag{3}$$
The most important simplification present in $(1)$ is that it assumes $c_0(\ce{H3O+}) \ll c_0(\ce{HCl})$ or — equally valid — $c_\mathrm{initial}(\ce{H3O+}) \ll c_\mathrm{final}(\ce{H3O+})$. In that case, it can be equated that $[\ce{H3O+}] \approx [\ce{Cl-}]$ which is used to reduce the number of independent variables and solve the equation. This will not be the case in this calculation with $c_0(\ce{HCl}) = 10^{-8}~\mathrm{M}$ and therefore we need to explore other methods. What we can say is shown in $(4)$.
$$\begin{align}[\ce{Cl-}] + [\ce{HCl}] &= c_0(\ce{HCl})\\ c_0(\ce{H3O+}) + [\ce{Cl-}] &= [\ce{H3O+}]\end{align}\tag{4}$$
$c_0(\ce{H3O+})$ is known from the autodeprotonation of water $(5)$ from which follows that $c_0(\ce{H3O+}) = 10^{-7}~\mathrm{M}$.
$$\begin{align}\ce{2 H2O <=> H3O+ + OH-}&&K_\mathrm{w} = 10^{-14}\end{align}\tag{5}$$
Now, finally, we have enough information to solve the equation.
$$\begin{align}K_\mathrm{a} &= \frac{(10^{-7} + [\ce{Cl-}])[\ce{Cl-}]}{c_0(\ce{HCl}) - [\ce{Cl-}]}\tag{6.1}\\[0.8em] K_\mathrm{a} &= \frac{10^{-7}\times [\ce{Cl-}] + [\ce{Cl-}]^2}{c_0(\ce{HCl}) - [\ce{Cl-}]}\tag{6.2}\\[0.8em] K_\mathrm{a} c_0(\ce{HCl}) - K_\mathrm{a} [\ce{Cl-}] &= 10^{-7}[\ce{Cl-}] + [\ce{Cl-}]^2\tag{6.3}\\[0.6em] 0 &= [\ce{Cl-}]^2 + (10^{-7} + K_\mathrm{a})[\ce{Cl-}] - K_\mathrm{a} c_0(\ce{HCl})\tag{6.4}\\[0.6em] [\ce{Cl-}]_{1/2} &= \frac{-K_\mathrm{a} - 10^{-7} \pm \sqrt{(10^{-7} + K_\mathrm{a})^2 + 4K_\mathrm{a} c_0(\ce{HCl})}}{2}\tag{6.5}\end{align}$$
Plugging in all the values (taking $K_\mathrm{a}$ from Wikipedia) and realising that only the positive square root makes sense, this is our result:
$$\begin{align}[\ce{Cl-}]_{1} &= \frac{-10^{5.9} - 10^{-7} + \sqrt{(10^{-7} + 10^{5.9})^2 + 4 \times 10^{5.9} \times 10^{-8}}}{2}\tag{6.6}\\[0.8em] [\ce{Cl-}]_1 &= \frac{-10^{5.9} - 10^{-7} + \sqrt{(10^{-7} + 10^{5.9})^2 + 4 \times 10^{-2.1}}}{2}\tag{6.7}\\[0.6em] [\ce{Cl-}]_1 &= 10^{-8}\tag{6.8}\end{align}$$
Thankfully, this equates to full deprotonation as the theory predicts. In the simplified context $(1)$, we just assume that complete deprotonation occurs. We can plug the value of $[\ce{Cl-}]$ into equation $(4)$ to get the final result:
$$\begin{align}c_0(\ce{H3O+}) + [\ce{Cl-}] &= [\ce{H3O+}]\tag{4}\\[0.4em] 10^{-7}~\mathrm{M} + 10^{-8}~\mathrm{M} &= 1.1 \times 10^{-7}~\mathrm{M}\tag{7}\\[0.4em] \mathrm{pH} = -\lg [\ce{H3O+}] &= 7\lg 1.1 = 6.959\tag{8}\end{align}$$
You experience a very slight decrease in $\mathrm{pH}$ but the principal contributor of $\ce{H3O+}$ ions is still the autoprotonation of water.
Suppose we have a 10^-8 M HCl solution.
We have: Mass balance: [H3O+] = [Cl-] = 10^-8 (M). Charge balance: [H3O+] = [Cl-] + [OH-]. Autoprotolysis of water: [H3O+] * [OH-] = 10^-14.
We multiply the charge balance with [H3O+] and get: [H3O+]^2 = [H3O+] * [Cl-] * [H3O+] * [OH-] = [Cl-] * [H3O+] + 10^-14 => We insert the value of [Cl-] and get: [H3O+]^2 = 10^-8 * [H3O+] + 10^-14 => [H3O+]^2 - 10^-8 * [H3O+] - 10^-14 = 0
We solve the equation for [H3O+] and get:
[H3O+] = 1,0512*10^-7
pH = 6.98 ≈ 7
– Bive Mar 21 '17 at 21:59
