I know things dissolve quicker in hotter solvents but I was wondering if there existed an exception to the rule. If not water, then what about other solvents and/or non-solid solutes?
Asked
Active
Viewed 146 times
-4
1https://chemistry.stackexchange.com/questions/21855; https://physics.stackexchange.com/questions/311409/ – andselisk Jan 04 '23 at 18:46
3Note that better and faster are 2 different things. A compound may dissolve at lower temperature more ( thermodynamics), but slower (kinetics). – Poutnik Jan 04 '23 at 20:55
Just one example is Poloxamer 407 which forms a hydrogel at room temperature at sufficiently high concentration. Adding solid Poloxamer 407 to water at room temperature would easily result in Poloxamer 407 powder encapsulated in gel which would strongly slow down the dissolution process. At a colder temperature, such as 4 °C, the gel does not form, so dissolution is typically achieved in a shorter time.
So yes, there are examples of compounds that dissolve faster in colder conditions. As usual when it comes to kinetics, the mechanism is highly relevant.
Snijderfrey
- 997
- 6
- 16
1Kind of similar when classical starch sol/gel is to be prepared, in iodometry or culinary context. It must be suspended in cold water before mixed with hot one. – Poutnik Jan 05 '23 at 11:34
