In Bitcoin's proof-of-work system, consensus on which chain of blocks should be considered the "true" block chain is based only(?) on which chain is longer.
Accordingly, to quote a nicely written answer by Nate Eldredge, a typical 51% attack would look like this:
Attacker privately starts mining their own chain, which diverges from the main chain at some block N.
Attacker deposits coins to your business, sending them from address A. Call this transaction X.
Attacker inserts in his own chain a transaction X' which conflicts with X; typically X' sends the coins from address A to another address belonging to the attacker.
Attacker waits for several confirmations of transaction X, in blocks N+1, ..., N+6 (replace 6 with however many confirmations your business wants) of the main chain.
Once there have been enough confirmations to satisfy you, you deliver goods or services to attacker.
Attacker releases his own chain, which now has blocks up to, say, N+50. Being longer, this chain is accepted by the network. This chain doesn't contain the transaction X but instead X', so you don't have the coins you thought you did.
Notice that up until Step 6, everything on the network looks completely normal; only the attacker knows what is going on.
My question then is: why doesn't bitcoin specify a maximum duration of time and/or a maximum number of confirmations, after which a competing/forking block is rejected even if it's backed by a longer chain of (secretly premined) child blocks?
To summarize this idea in pseudocode:
CUTOFF_TIME = 1200 # seconds
CUTOFF_CONFIRMATIONS = 3
is_acceptable_block(new_block, parent_block):
if not is_valid_block(new_block):
return false
if is_first_child(new_block, parent_block):
return true
old_block = get_first_child(parent_block)
if age_difference(new_block, old_block) > CUTOFF_TIME:
return false
if child_chain_length(old_block) > CUTOFF_CONFIRMATIONS:
return false
return child_chain_length(new_block) > child_chain_length(old_block)
If this would be viable, then the 51% attack scenario described above would become much harder; and as a result, the amount of time/confirmations to wait for before a transaction can be safely believed would decrease, right?
"you're now expanding the circle of people you trust to the people relaying the chain"
. And by that I mean: aren't you already (in the bitcoin network as it exists today) extending trust to relaying nodes anyway? I thought that this trust issue already existed, but that it poses no problem given the incentives of nodes to keep the network as a whole in a healthy state. – Will Jan 18 '15 at 01:16aren't you already extending trust to relaying nodes
Very little. They can avoid telling you about blocks, but as soon as you connect to one node that isn't cooperating in the embargo, you'll download the best chain. – Nick ODell Jan 18 '15 at 02:40
