Have invested in good networking hardware and researching on failover scenarios using 2 connections - the home broadband and mobile LTE one - as well as load balancing to increase download/upload speeds utilising both connections.
There is a document from a load balancing workshop organised by networking gear manufacturer available online, which reads:
https://mum.mikrotik.com/presentations/PL12/Load_Balancing_workshop.pdf
"Load Balancing is a technique to distribute the workload across two or more network links in order to maximize throughput, minimise response time, and avoid overload"
Initial block download is notoriously painful procedure for everybody. Guess many of us have unlimited Internet connections at home as well as same mobile data plans. Network gear that does load balancing is affordable.
Has anybody tried it and if it helps - which approach/algorithm is the best?
Many thanks, Yuri
If that also applies to your system, it should be addressed first.
– RedGrittyBrick Mar 25 '24 at 15:40
