Total solar eclipses are extremely rare. It's of great coincidence that we live in a period where the Moon is just the right distance (as with time it's receding away) to have the same apparent size in sky as the Sun on Earth. My question is, does any other planet or moon or any other minor body also has one body (with which it is gravitationally bound, making the process recurrent) which is of the same apparent size as the apparent size of Sun in the sky. Note that I'm just asking for possibility of totality: occultation, transits and partial/annular eclipses don't count. Although if the annular is as good ours, then I'm willing to give it a pass. Just the ring should be thin enough!
peakcipher
  • 71
    Several moons cause solar eclipses, but not with the close size match. Here's a recent answer I wrote on eclipses on Neptune: https://astronomy.stackexchange.com/a/55620/16685 OTOH, viewing a solar eclipse from an ice or gas giant would be a bit tricky. Where would you stand? ;) – PM 2Ring Feb 10 '24 at 17:45
    That's a great answer. I was looking something similar to this. And, I don't have to care about standing, I will just use Stellarium lol. – peakcipher Feb 10 '24 at 21:03
    @pekcipher. Whey do you think that the matching size is what makes a total eclipse? If the angular size of the moon is equal to or greater than that of the sun the eclipse will be total. There are many more solar system objects whose angular sizes as seen from their companion worlds are much smaller or much larger than that of the Sun at that distance, than there are ones with exactly the same angular size. – M. A. Golding Feb 10 '24 at 22:59
    @M.A.G If the angular diameter of the eclipsing body is much larger than the Sun's, you probably won't see the corona. Of course, at the distance of Uranus or Neptune, the angular diameters of the Sun & corona are pretty small. Also, the diamond ring effect & Baily's beads are most spectacular when the sizes match. https://en.wikipedia.org/wiki/Baily%27s_beads – PM 2Ring Feb 11 '24 at 00:36
    @PM2Ring You won't see all of the corona at once, but immediately after the eclipsing body covers the photosphere, you'll see the part of the corona that isn't eclipsed. – John Doty Feb 11 '24 at 01:26
  • @John Fair point. I guess a segment of corona is better than nothing. – PM 2Ring Feb 11 '24 at 01:32
  • You are confusing totality, which is not at all rare in the solar system, with what is actually rare: an object that provides both annular and total eclipses. It may be that the Earth's moon is the only one. – antlersoft Feb 11 '24 at 17:21
  • @antlersoft Hmm, the totality is not the point, the point is the apparent size of the occulting body is almost equal to apparent size of Sun. – peakcipher Feb 11 '24 at 18:48
Many (most?) moons, including our own, experience eclipses by their parent planet. Moons can eclipse the Sun as seen by other moons. Compiling a full catalog would be a bit of research.
John Doty
  • 1,876
