Let's start with a stationary Earth. If we smash a few Mercury-sized objects into the Earth, the Earth begins to accrete mass. Repeat this step with larger and larger objects, until we start impacting Jupiters into the growing Earth. If we cause an even larger planet to crash into the Earth (say, a 3-Jupiter mass object), we will eventually reach the boundary between planets and brown dwarfs. If we continue accreting more Jupiter-sized objects to the Earth, we will pass the brown-dwarf limit of 90 Jupiter masses, we will reach stellar masses. But instead of turning into a star, this object either stays molten as a "planet", blows itself apart, or even collapses into a black hole. I tested this in Universe Sandbox 2 about 20 times, and none of them coalesced into a star. Why does this happen, and would this be realistic?
have you also tried asking the developers of universe sandbox this question? – Aaron F Nov 18 '20 at 20:41
Maybe somebody experienced with the subject can define the tag [tag:universe-sandbox], please? – B--rian Mar 21 '21 at 14:13
1@B--rian Doing that now... – WarpPrime Mar 21 '21 at 17:23
Who can say for sure? I guess the physics in Universe Sandbox is not good enough.
What I would say though is that if you have a "protostar" that contains a higher proportion of heavy elements than a usual star, then the threshold for ignition of hydrogen will be lower than 75 Jupiter masses (e.g. How large can a ball of water be without fusion starting? ). If on the other hand it contains very little hydrogen (not enough to sustain a significant main sequence reaction rate), then it will be forced to rely on He, C or even O burning that require significantly higher temperatures and a much more massive object - probably in the region of 1000 Jupiter masses.
However, if you are telling us that some of your simulations collapse into a black hole at 90 Jupiter masses, that suggests that a more simple explanation is that the simulation physics is incorrect. I also think it would take a very peculiar composition indeed to avoid a nuclear burning phase prior to collapse to a black hole, even if you give the object several stellar masses of material.
- 151,483
- 9
- 359
- 566
Only 1 simulation ended as a black hole, as the "protostar" began to shrink in radius as the mass grew, then reached critical density. – WarpPrime Nov 18 '20 at 15:26
"higher proportion of elements" seems like an understatement. According to Wikipedia earth is 30% iron, 30% oxygen and only minuscule amounts of hydrogen and helium. I am assuming other rocky planets are similar. Scaled to 1000 Jupiter masses, you get a sun-mass object which is 30% iron. – kutschkem Nov 18 '20 at 15:41
@kutschkem The OP is also throwing Jupiter-like bodies into the mix. But even if they were just using terrestrial planets, the super-Earth would inevitably accumulate some hydrogen. Jupiter's mass is around 317 Earth masses, and there's only around 2 Earth masses of terrestrial material in our Solar System (apart from what's buried inside the Sun & the giant planets). So to get 90 Jupiter masses of rocky matter you'd have to raid over a quarter of a million stellar systems. In transporting all that stuff to one location, you're bound to pick up some hydrogen too, since it's everywhere. – PM 2Ring Nov 18 '20 at 17:01
To create a star you need hydrogen and helium. Therefore, you need a gas giant, not a terrestrial planet, to let it turn into a brown dwarf, and eventually into a hydrogen-burning star. You write of accretion of Jupiter-sized objects, but are these gas giants? Universe Sandbox features some exoplanets whose composition is unknown well.
When I make Jupiter have 80 times its mass in Universe Sandbox, it turns into a red dwarf star. When I make it have ~50 Jovian masses, it starts to emit own light already. However, it's very difficult to add mass by colliding bodies with each other in Universe Sandbox, as this makes them lose mass rather than gain any. I did this the other way round: After a collision with Proxima Centauri, guess what? Proxima lost so much mass that it eventually had about Saturn's mass, no more emitted own light and looked like an ordinary gas giant.
- 1,538
- 6
- 16
1I didn't ask about starting with a Jupiter-like planet and turning it into a star. Please read over my question again. – WarpPrime Jun 12 '21 at 01:18
@fasterthanlight I know, and I answered you that you need hydrogen and helium which you find in gas giants. You cannot ignite rocky planets. – John Jun 12 '21 at 04:20
@fasterthanlight Not to be a pain, but John is actually correct. You can't get fusion without something that will fuse easily, which is hydrogen and helium. The low energy point for fusion is iron, that is fusion that takes smaller elements and produces iron will generate energy but fusion that results in anything larger than iron consumes energy. So yes, you can fuse the material in regular planets, but you're not going to get enough energy for a sustainable reaction - it will never be a star. – Donald.McLean Jun 12 '21 at 20:06
